minus
I am currently using a francis 5.5 foot scanner antenna which is made of fiberglass mounted using a stake pocket mount on a 2001 dodge ram. Reception is pretty good. However it seems that the 36" stainless steel we have mounted on a hood channel firestick mount on a ford excursion seems to pull in signals alot better. Both antennas cover low band basically to the 512 mhz spectrum. Am I missing something here is the shorter antenna better quality?
http://www.walcottcb.com/mon3-scanner-antenna-p-382.html
That is the antenna for the excursion. The francis just appeared to have a small piece of copper wire inside.
I am considering switching my vehicle to the stainless one.
