Go Back   The RadioReference.com Forums > Service Specific Monitoring > Skip / Tropospheric Ducting Forum
Skip / Tropospheric Ducting Forum - Discussion of Skip and Tropospheric Ducting Monitoring
Old 08-26-2018, 4:34 PM
Dispatrick's Avatar
Default scanning 28.000 to 54.000 Modulation
When scanning between 28.000 and 54.000 which FM modutaiton is best? Regular FM or narrow?
I normally keep my scanner on auto modutaiton when scanning, but was curious if just setting one or the other would have any affect on my reception?
Thank you,
Dispatcher Patrick a.k.a. "Dispatrick"
Old 08-26-2018, 4:59 PM
mmckenna's Avatar
Amateur radio uses 28-30MHz, for the most part, so you'll find FM, AM, SSB, etc.
From 30-50MHz, most of what you are going to run across is going to be FM. FM wide, or normal, depending on your scanner. In the USA, the FCC never required stations in that segment of the band to go narrow.
Between 50-54MHz, it's the 6 meter amateur band, AM, FM, SSB, etc.
For the amateur bands, you can look at on line band plans. Those are a gentleman's agreement, but for the most part, amateurs tend to follow it.
