Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Software Defined Radio
Software Defined Radio A forum for general discussion of software defined radio (SDR) receiver equipment.
Old 10-24-2012, 8:47 PM
Default $20 SDR Radio
This is nothing too new, but I had to try it out. A friend of mine picked up one of the tv tuner cards (Realtek RT 2832u/4000) that were reported to be good for a cheap SDR. I didn't think it would work but, wow, after just a little bit of playing around today it was pulling in signals. The antenna that I quickly connected was not overly secure, my filter parameters are probably not set up right, and I'm sure I'm off on a bunch of other settings, but even with all of that it was working.
I was surprised at the amount of computer resources that were required though. My desktop is a single core machine that is about 7 years old. (I plan to build a new quad core system in the next month or two).
In any event, I always make a little video of these things, so here's a clip of this chip and SDR# software.
I'm open to comments and suggestions.
$20 SDR TV Tuner Card - Unboxing - YouTube
Thanks for taking a look,
Dan
Old 10-24-2012, 10:51 PM
xeno194's Avatar
First what OS are you running. Windows 7 or vista.
Here are some quick sdrsharp settings/tweaks
Lower your sample rate to about 1.024 msps
set the rf gain to auto
set filter audio to off
set filter order to about 10
Also your youtube videos are awesome.
996T/RTLSDR/BC244CLT X3/UV3R+/UV-5RE/Afedri SDR Net
http://www.mikexeno.com
Old 10-25-2012, 8:17 AM
Default Thanks
Fantastic. Thank you very much for taking a look and for the tips. Will do.
I'm running Windows 7.
Dan
Old 10-25-2012, 12:29 PM
xeno194's Avatar
I will try to write up some quick tweaks to the OS if i have some time later and it will help speed up your system.
What version are you running? The stable release of SDR# or the latest build. I would suggest always using the latest build.
SDR# Dev (Continuous Integration, Last Changed Rev: 968 )
SDR# RTLSDR Plugin (Continuous Integration, Last Changed Rev: 968 )
Old 10-25-2012, 5:19 PM
StephenVa's Avatar
Well worth the 20 bucks and pretty easy to set up. I'm going to pick up a couple extras just to have around.
My Listening Desk
Old 10-25-2012, 5:24 PM
Default Cool
Very kind of you. I believe it is the latest revision. I've been out most of the day - sorry to not have gotten back to you earlier.
Dan
Old 10-26-2012, 8:41 AM
Send a message via AIM to scottb908
Where did you order hem from and any directions for setting it up. That looks great to have with my laptop.
Scott
73's from KB1YKJ
Listen to my feed at http://www.radioreference.com/apps/audio/?feedId=5053
Old 10-26-2012, 9:48 AM
xeno194's Avatar
Everything you need to know about the usbsdr is here
Mike Xeno: RTL SDR
You are going to have to go to a lot of external links but i think i covered everything to get it up and running.
The most important thing is the zadig drivers.
Old 10-26-2012, 10:20 AM
Thanks Mike. I'll try to take a look at that later today. Very appreciated.
@ Scott - I bought mine from Amazon. Shipping was supposed to take a month or more; it got from Hong Kong to Maryland in about 10 days, I was surprised.
Setting it up was not too difficult but takes a little bit of playing around - at least it did for me. I tinker with computer system but am no expert in any way.
Dan
Old 10-26-2012, 3:24 PM
W9NES's Avatar
Cool Video Dan.
Tim DeLong --W9NES--GMRS KAF3207--**Monitoring all of Metro Indianapolis/Marion County and Central Indiana and The World from**The Northwest Communications Center**
Tags
cheap, sdr radio
