Originally Posted by foxtail
What does the swap I & Q do? I had it checked so maybe I might be able to get it lined up without. ....Well, just un-cheked the swap i&q and the line is just off enough that the ppm will line up. Thanks for the help. P.S. is it unusual to have the ppm set as high as 89-90. The dongle has been plugged in for hours so it should be stable.
Your number is not unreasonable. I have two of them, one is at +74 and the other at +56.
Since these things cost less than a TCXO for my FT857, accuracy and stability are a trade off.
Craig
