  #101 (permalink)
Old 03-14-2014, 3:24 AM
br0adband's Avatar
Originally Posted by Pyr8 View Post
The link is dead!
I have the V1174, just need the DLL's!
If you'd note the name of the file, it's *not* the same thing: one is sdr-nightly (which is SDR# itself), the other is sdr-nightly-rtlsdr (which is only the RTL-SDR dll files), two different things.
Anyway, to clear up the fuss and muss from this point further and for anyone that needs it, here is SDR# v1.0.0.1174 clean and pure, "stock," unchanged, unmodified, with the appropriate RTL-SDR dll files included in one archive, ready to go. I just created this, I just tested it on 3 different machines, and as long as you have your Zadig drivers installed properly, all that's needed is to extract this archive someplace (it's a folder inside the archive, sdrsharp is the name of the folder) and inside that you'll find all the necessary stuff for a clean fresh start. Extract, run the .exe, select the RTL-SDR/USB device, and hit Play and you should be good to go.
https://dl.dropboxusercontent.com/u/...lean_v1174.zip
For the overly cautious and perhaps even paranoid to some degree, I sent the archive to VirusTotal for testing as well, here's the link with the relevant results:
https://www.virustotal.com/en/file/6...is/1394781674/
The one single "hit" there is because of a well known and misunderstood glitch with Norton/Symantec antivirus software - it's clean, seriously, but it's your choice if you wish to use it or not.
The difference between genius and stupidity? Genius has limits.
  #102 (permalink)
Old 03-14-2014, 3:28 AM
Pyr8's Avatar
Works...thank God! lol
Thanks!
Gota have more toys!
  #103 (permalink)
Old 03-14-2014, 11:00 AM
DaveNF2G's Avatar
Error
Something went wrong. Don't worry, your files are still safe and the Dropboxers have been notified. Check out our Help Center and forums for help, or head back to home.
David T. Stark
NF2G WQMY980 KYR7128
  #104 (permalink)
Old 03-14-2014, 2:37 PM
br0adband's Avatar
Not sure what that's in reference to but the link works fine from my end, also tested using Tor (so my Dropbox login cookie wasn't relevant) and from several different IP addresses as well. If needed I can host it elsewhere, not a big deal I suppose.
  #105 (permalink)
Old 03-14-2014, 3:17 PM
RonnieUSA's Avatar
Just worked fine for me.
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
  #106 (permalink)
Old 03-15-2014, 6:28 AM
hkrharry's Avatar
Member - RR DB AdminMo/Ks
Ditto work for me, Tnx OM!
  #107 (permalink)
Old 03-15-2014, 1:55 PM
Works for me. I had to do a complete wipe of my computer, so I lost my working set up of SDR#/UniTrunker/ DSDPlus. I just bought a new antenna to pick up my local trunking system... so now i can use it! Thanks
  #108 (permalink)
Old 03-15-2014, 3:25 PM
Thanks for posting the 1174 zip file.
I'm unable to set the UniTrunker installation directory in the SDR# GUI because I can't see the "File" button to select it and the panes at the left can't be resized. Would someone who has this configured and working post the relevant entries from their SDR# config file so I can copy and paste it into mine.
Thanks and 73,
Chris
  #109 (permalink)
Old 03-17-2014, 5:22 AM
PiccoIntegra's Avatar
I've updated the Trunker plugin for the newer 1179 and 1183 SDRSharp plugin standards.
Please try it out and see if it actually works.. it does load in the newer version however.
-Scott
Code:
Mar 17, 2014
Plugin updated for recent SDRSharp releases > 1179
Fixed obsolete reference to GetSpectrumSnapshot(byte[]) in TrunkerPanel.cs, now uses float type
TrunkerPlugin.cs now uses new interface implementation.
File Type: zip SDRSharp.Trunker.ZefieMod.v1.2013.430.1(1179).zip (53.7 KB, 6005 views)
  #110 (permalink)
Old 03-19-2014, 1:14 PM
DaveNF2G's Avatar
Got it this time. Thanks!
David T. Stark
  #111 (permalink)
Old 03-22-2014, 5:01 PM
Has anyone noticed that the sample rate is 192K? This appears in this new build 1189. Does this affect anything? I changed it back to 48K.
  #112 (permalink)
Old 04-27-2014, 10:06 AM
Default error with SDR# ver 1.0.0.1193
Problem solved.
Please delete.
  #113 (permalink)
Old 05-01-2014, 10:46 AM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Default SDR# with trunking has been updated
How about sharing what you did to solve gts problem so others might learn?
Mike.
  #114 (permalink)
Old 05-01-2014, 10:55 AM
Default Problem solved
Originally Posted by dhoover View Post
Problem solved.
Please delete.
I was trying to run this with SDR# build 1193. When I changed to build 1174, everything worked fine.
I just hadn't searched long enough on the new trunker plugin version.
Hope this helps.
Dave
  #115 (permalink)
Old 05-01-2014, 11:22 AM
mk262's Avatar
Good work PiccoIntegra
  #116 (permalink)
Old 05-01-2014, 10:27 PM
mk262's Avatar
Cross post, but I uploaded a copy of 1199 with Picco's trunking plugin (assuming he's ok with that) in light of Youssef having his mental breakdown.
  #117 (permalink)
Old 05-02-2014, 2:23 PM
Ain't my code, ain't my business..
  #118 (permalink)
Old 06-08-2014, 8:51 PM
-Scott
Code:
Mar 17, 2014
Works in rev 1299
  #119 (permalink)
Old 07-13-2014, 12:55 PM
Default Manual
Some one needs to make a manual. I cant figure out how to enter a freq. to park the trunker program on in the plugin. Too meany pages in the thread and scattered all over the place, unable to find the info...
  #120 (permalink)
Old 07-19-2014, 4:24 PM
DeKP's Avatar
amen
