I could use some help and suggestions.
I have SDRSharp up and running. Set to control channel. Unitrunker shows activity. (I am using 2 TV28T V2s)
The second instance of SDRSharp is up and running changing frequencies as it should.
I have 2 problems.
1 When I try to calibrate to a frequency. I click "front end", change the "frequency correction" and nothing happens. I have tried everything I can think of to get it to do anything at all but nothing changes.
2 When I run DSD every once in a while I will get some garbled sound but mostly it stays silent. I think the problem is with the "frequency correction". I "hope" by solving problem one it will solve problem 2.
Does anyone have any advice or suggestions?
Thank you for your time.
I have 2 problems.
