Old 04-07-2014, 8:48 AM
RonnieUSA's Avatar
Default SDRSharp Tuner AGC
Does anyone use it?
The reason I ask is, I was having problems with 1 frequency not sounding very good, signal was up, and down, but after enabling it it's very stable, and sounds great with no drift.
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
Old 04-07-2014, 9:59 AM
DaveIN's Avatar
Founders Curmudgen
I use it most of the time. There are occasions when you may need to fine tune a weak signal manually.
Make sure the offset correction (ppm) is correct at the bottom of the Configuration settings.
Pop' Comm Monitoring Station ID: KPC9DV
CRB Research Monitor Station Registry: KIN9GP
GMRS: WQKL769
MARC ID:3126326
The BEST scanner or receiver is the one you using right now.
Old 04-07-2014, 10:14 AM
RonnieUSA's Avatar
It just seems to work better now, and the ppm is set to 29.
