  #2101 (permalink)
Old 06-25-2018, 11:10 AM
Originally Posted by maus92 View Post
OK, thx.
What does the "tsbks" value represent when decoding?
Does the program output reception history to a log file?
How do I setup Wireshark to analyze the control channel data stream?
TSBK's are individual "trunk signaling blocks" or packets of data that convey things like group voice channel grants, group voice channel updates and the like. Essentially once you are tuned to a control channel you should see this counter rolling as signaling info is received and reconstructed from the p25 decoder.
By increasing the value of the -v parameter you can control the detail level of the stderr.2 log file. The range is presently 0 (silent) to 11 (maximum debug) with "1" being a good number to simply monitor the history of what op25 has been tuning in to.
Wireshark is not presently operable - the wireshark decoder is out of date and does not function correctly. If you'd like to see P25 protocol exchange, turn the log level up to 10. (-v 10)
  #2102 (permalink)
Old 06-25-2018, 5:18 PM
maus92's Avatar
When I add the -v option, any value more than 4 creates a bunch of garbage to be written to the screen. Where does the stderr.2 log file reside?
BCD536 | G5 | PSR800 | SDS100
  #2103 (permalink)
Old 06-26-2018, 5:32 AM
You have to redirect the stdout and stderr to a file. See the bold bit below.
./rx.py --nocrypt --args "rtl=0" --gains 'lna:36' -O 'default' -S 960000 -q 0 -d 0 -v 1 -2 -V -U -T trunk-test.tsv 2> stderr.2
The stderr.2 file (or whatever you name it) ends up in the current directory (usually ./apps)
  #2104 (permalink)
Old 07-04-2018, 1:11 AM
Default <f>req button
Has the <f>req button been disfuncticated, I thought a couple months ago i could just scoot around control channels using that button?
  #2105 (permalink)
Old 07-04-2018, 7:21 AM
You can enter a frequency using "f" but I'm not sure of a req button.
  #2106 (permalink)
Old 07-04-2018, 5:24 PM
in the terminal window
(f)req (h)old (s)kip (l)ock (q)uit (1-5)plot (,.<>)tune
  #2107 (permalink)
Old 07-04-2018, 5:33 PM
without using the -T in my command line
  #2108 (permalink)
Old 07-05-2018, 10:20 AM
It'll give me an input prompt, but it won't change to the frequency i enter
  #2109 (permalink)
Old 07-05-2018, 11:30 AM
Sounds like a bug. I'll look more later.
  #2110 (permalink)
Old 07-05-2018, 4:40 PM
And has anyone told you lately how awesome you are. Well You ARE. Thank you for all you do.
  #2111 (permalink)
Old 07-07-2018, 6:52 PM
maus92's Avatar
Does OP25 have a "wildcard" search logic in the whitelist? In other words, if I wanted to scan TG between 7500 to 7599, could I make a single entry like 75** in the whitelist?
  #2112 (permalink)
Old 07-08-2018, 6:51 AM
No, nothing like that at present, but it's an interesting idea.
  #2113 (permalink)
Old 07-15-2018, 8:21 PM
It was a bug and if you pull an update it should now be fixed. Word of caution: it's not very graceful and has potentially unexpected behavior if you tune to a new frequency while trunking is active.
  #2114 (permalink)
Old 07-15-2018, 8:22 PM
maus92's Avatar
Is there a procedure to follow to update, or do you use the OS's built in update function?
  #2115 (permalink)
Old 07-16-2018, 5:31 AM
cd ~/op25
git pull
No changes to library code so you don't need to make or make install.
