  #1481 (permalink)
Old 11-17-2017, 9:54 PM
Originally Posted by boatbod View Post
I've tweaked the formats a little to try to line stuff up in the log. More importantly, the new code has been merged back into the master branch of my repo. If you tried the alpha version on the test branch, "git checkout master" should get you back where you need to be.
Further decode of the LCW parameters might be useful, as would decode of TSBKs and PDUs. I'll look in to this as time permits.
For anyone who didn't follow the last week or so, you can now add "--nocrypt" as a command line option to suppress the playing for encrypted audio.
It does seem to be suppressing the encrypted audio (my ears thank you), any way to get it to move to the next transmission instead of holding till the encrypted one is done ?
Rob
Pro-651 Pro-18
  #1482 (permalink)
Old 11-17-2017, 10:16 PM
is there any special command lines that i have to add to get it to work on phase 1 is it the same install instructions
  #1483 (permalink)
Old 11-17-2017, 10:18 PM
From the Read Me file: NOTE: For phase1 voice the "-V" option is not used. Instead the
"-w" option is used (see AUDIO SERVER section, below). For P25 phase 2/TDMA,
the "-2" option is required in addition to the "-w" option.
Rob
Pro-651 Pro-18
  #1484 (permalink)
Old 11-17-2017, 10:24 PM
Misread that. so cd ~/op25 then git checkout master then git pull is what I did.
Rob
Pro-651 Pro-18
  #1485 (permalink)
Old 11-17-2017, 10:37 PM
encrypted audio is still coming through as garbled
  #1486 (permalink)
Old 11-17-2017, 10:40 PM
Did you insert --nocrypt into the command line ?
Rob
Pro-651 Pro-18
  #1487 (permalink)
Old 11-17-2017, 11:29 PM
yeah that worked thanks what is the purpose of logging the traffic
  #1488 (permalink)
Old Yesterday, 2:19 AM
PiccoIntegra's Avatar
Just an FYI...
Due to the ezpwd lib, I had to modify /gr-op25/CMakeLists.txt to get it to compile on my system. The debug and release flags are redundant in this case.
Code:
~/gr-op25 $ git diff
diff --git a/CMakeLists.txt b/CMakeLists.txt
index c8bfb41..aa013a3 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -1,8 +1,7 @@
 cmake_minimum_required(VERSION 2.6)
 project(gr-op25 CXX C)
-set(CMAKE_CXX_FLAGS_DEBUG "-std=c++11")
-set(CMAKE_CXX_FLAGS_RELEASE "-std=c++11")
+set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
 add_subdirectory(op25/gr-op25)
 add_subdirectory(op25/gr-op25_repeater)
  #1489 (permalink)
Old Yesterday, 6:47 AM
Originally Posted by PiccoIntegra View Post
Just an FYI...
Code:
@@ -1,8 +1,7 @@
The commit should have included the changes to the top level CMake to enable ezpwd to compile. Did you nuke the build directory and start over with a fresh cmake?
  #1490 (permalink)
Old Yesterday, 6:49 AM
Rob
If you want proper audio you absolutely need the -V (vocoder flag). There is no magic to enabling both phase 1 and 2 other than putting a -2 on the command line.
  #1491 (permalink)
Old Yesterday, 7:17 AM
It was a fresh install from master, so everything was nuked. The last change for the top level CMake was three days ago, and I had to modify it to compile on my machine. Hence the FYI...
  #1492 (permalink)
Old Yesterday, 7:40 AM
Curious, thanks. It obviously compiled on my system, but I will double check if I can reproduce the issue.
Was your build type set to something other than Debug or Release?
  #1493 (permalink)
Old Yesterday, 9:00 AM
Code:
PyBOMBS._process_thread() - DEBUG - Executing command `$ cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo -DCMAKE_INSTALL_PREFIX=/home/scott/target  -Wno-dev'
  #1494 (permalink)
Old Yesterday, 10:27 AM
Code:
Ah yes, that explains it: -DCMAKE_BUILD_TYPE=RelWithDebInfo
I made the change to CMakeLists.txt and pushed it.
  #1495 (permalink)
Old Yesterday, 5:57 PM
Not real sure why but I keep getting messages that Cinnamon just crashed and I'm in Fall back mode. Any thoughts on this ?
Rob
Pro-651 Pro-18
  #1496 (permalink)
Old Yesterday, 9:51 PM
Rob
I doubt op25 or the rtl driver is causing the Cinnamon crash. Is there any extra info in either syslog or dmesg to narrow it down a bit? At a guess it's probably the video driver.
  #1497 (permalink)
Old Yesterday, 10:28 PM
This is a copy of the syslog from today, it's greek to me so hopefully you can make some sense of it ?
https://www.dropbox.com/s/w8wd5wg9up...slog-copy?dl=0
Rob
Pro-651 Pro-18
