Old 02-02-2015, 6:22 PM
Default Raspberry Pi 2 Released
From their web page:
Let's get the good stuff out of the way above the fold. Raspberry Pi 2 is now on sale for $35 (the same price as the existing Model B+), featuring:
A 900MHz quad-core ARM Cortex-A7 CPU (~6x performance)
1GB LPDDR2 SDRAM (2x memory)
Complete compatibility with Raspberry Pi 1
Because it has an ARMv7 processor, it can run the full range of ARM GNU/Linux distributions, including Snappy Ubuntu Core, as well as Microsoft Windows 10.
Raspberry Pi 2 on sale now at $35 | Raspberry Pi
Old 02-02-2015, 7:46 PM
Markb's Avatar
Oh Boy! Maybe we have enough horsepower finally to run some of the SDR software suites or DSD/DSDPlus!
I will have to pick one up for sure.......
Old 02-02-2015, 10:51 PM
krokus's Avatar
I wonder which version of Two-Tone Decode will work better?
Sent via Tapatalk
Old 02-03-2015, 10:26 PM
I REALLY, REALLY would love to put OP25 on this thing and build a portable or mobile P-25 scanner, it would be really cool even if you could only listen to a small pre-programmed list of talkgroups. I know next to nothing about ARM, is it possible to put Mint or Ubuntu on this contraption?
My big dream is to build a slightly-oversized mobile scanner with 4-8 ARM processors each running OP25 with discrete RTL SDR sticks, and simply park each instance of OP25 on a single talkgroup...
"Huhh?? Of COURSE I don't have enough radios, shouldn't that be obvious??! My vehicle has lots of space to put more radios, I certainly do NOT have enough!"
Old 02-03-2015, 10:43 PM
Markb's Avatar
The specs say it will run at least a form of Ubuntu. I would be surprised if OP25 would run on one. I am not even sure if any form of DSD will work. Either way, we are getting close to having the computing power to do these kind of projects.
I really want to get my hands on one.....
Old 02-03-2015, 11:24 PM
Yeah, you're probably right. I can barely run OP25 on a 2 Ghz AMD box with 1 Gig of ram; it runs pretty good but it takes 100% CPU all the time. Perhaps you could split up certain key functions that consume a lot of CPU and run OP25 or other DSD programs on 2 or even 3 of these units chained together. But yeah, I definitely need to play with one of these as well!
Old 02-04-2015, 11:36 AM
I would be happy when i can use a Pi to send ADS-B Data over the network.
Nobody give me an answer for my question.
Old 02-05-2015, 11:12 PM
Spleen's Avatar
ADS-B dump1090
Old 02-06-2015, 6:30 AM
So how can i send UDP Data?
Old 02-06-2015, 6:44 AM
PiAware - build your own ADS-B ground station for integration with FlightAware
Old 02-06-2015, 6:48 AM
I use RTL1090 and Planeplotter.
Old 02-10-2015, 12:15 PM
Raspberry Pi 2 and a SDR dongle... interesting w the quad core 900 mhz seems like a home brew awesome scanner for less than 100.00 put in to the project could rival a high end scanner...
Old 02-15-2015, 11:08 AM
I doubt very much you will be able to run dsd on this r pi2. It needs lots of cpu to run even for desktop. And I doubt even more that you can find a R pi2 in Canada for 35 bucks!! Nope. I have 2 rpi+b I am still playing with. Just trying to find the right Linux to run. Have tried Kali 1.10...little slow. I think it would take quiet awhile for it to break my wpa password....like 30 days...lol
Old 02-15-2015, 11:20 AM
Is there any "ready to use" image for the pi?
Old 02-16-2015, 1:47 AM
Spleen's Avatar
Sure. There's links at the main Raspberry Pi site, and Google is your friend for finding others...
Old 02-16-2015, 3:45 AM
I search in German but the Results are very poor.
Old 02-16-2015, 10:52 AM
Hello,
I am partial to Ubuntu so I am using an Ubuntu/Linaro image from this thread.
Raspberry Pi • View topic - Ubuntu / Linaro for Raspberry Pi 2
73 Eric
Old 02-22-2015, 8:27 PM
Still don't see anyone posting there results on decoding dsd. With rpi2
Old 02-22-2015, 11:09 PM
kc2kth's Avatar
Just watched this and found it relavant to the discussion about the release of the Pi 2:
EEVblog #716 - Raspberry Pi 2 Xenon Flash Problem Explained | EEVblog - The Electronics Engineering Video Blog
Old 02-23-2015, 4:31 PM
Spleen's Avatar
http://forums.radioreference.com/dig...ml#post2338722
