Are there any (cheap) Dongle to send any kind of Text von Pc to Pc?
I know there are some Dongle out there but can the also work?
THX!
THX!
the are not that nice. The Output Power are to low.
hmm how far we could go. Some Km in the best ways.How far are you trying to send data?
Radio Amateurs could use 100W max. So...Output power is less than watt of the 433 MHz system.
sorry the Phone Coverage are not everything the best.'ve got a 1 mile link at work running on 900MHz radios. It's just water tank level data, so not much data.
500m for the start and after how far we could go. Some km would be nice an with an directional Antenna.What is your distance you need to cover?
USB and if it necessary Lan but I need a power source who sucks abroad.What sort of interface to do you need? -serial, USB, Ethernet?
Yes sometimes it not possible to use a Cable.Does it need to be wireless?
Again, what kind of through put are you looking for?
Ubiquiti has an IP radio in 900 MHz.
Yes! Transmit Data from Laptop A to Laptop B also Text.It sounds like you want to set up some sort of ad hoc network on the 70cm band. But what EXACTLY do you want to do?
haha i know what GSM is....GE made a line called iNEt. 900 MHz spread spectrum capable of up to 1 Mbps. Both serial and 802.3.
LTE Suport 5/30 but its a Network thing...You can go higher than 900 Mhz with Ubiquiti gear and get throughputs of over 10 Mb/s
bad idea onboard a Train....With the dish
a very very stupid idea...NanoStation M900 Loco: said:OPERATING FREQUENCY 902-928 MHz
interfere Wifi 2400 - 24832412-2462
interfere LTE (after 2020)3400-3700
interfere LTE (after 2020)3650-3675
haha i know what GSM is....LTE Suport 5/30 but its a Network thing...bad idea onboard a Train....
3ghz?! I have to check which freqs are for what.
EDIT:
The interfere the GSM on 880 - 915 MHz
sorry i dont understand what you mean with.Guess you are just SOL !!!
We have an HSMM network here in VE4 land. I use a 2.4 Ghz Ubiquity M2 Bullet modified to operate at 2.3 Ghz (in the ham band below WiFi channel 1). https://www.ubnt.com/airmax/bulletm/ It puts out about 0.6 watts. I feed it to a 36dBi grid dish on my tower. It plugs right in to the dish so there is no need for coax. With the dish, the effective radiated power is over 500 Watts. It lets me reach a node located 6 miles away. (This node ties in to the main HSMM network in a nearby city over a 23 mile 5 Ghz link).
The hams in the city are much closer together and don't need the gain. They can get by using Ubiquity Nano radios. https://www.ubnt.com/airmax/nanostationm/ They contain both the transmitter and the antenna.
The Bullet and Nano are essentially high power wireless routers that you plug in to your computer. Our network is private using the 44.x.x.x IP numbers reserved for amateur radio.
Well aware. I run a WISP almost entirely off of Ubiquiti radios. I stay mostly in 3.65, 5 GHz and 10 GHz.
I lost faith in HSMM back when they went several years without updating anything. Then Uni-II became available and I pretty much stay on that. My furthest shot is 19 miles on 5 GHz and runs 78 Mbps each way. The second furthest is 17 miles on 3.65 GHz. Nothing is meshed.
