  #361 (permalink)
Old 03-23-2018, 5:33 PM
Originally Posted by dseven View Post
Yes. Monitoring K6MDD now. Problem is .. I'm not sure if anyone's active on there It unmuted/muted once, with a strong spike on the FFT plot for a few seconds, but no voice. I think someone just "kerchunked" it
Try the TAC 310 DMR group. Lots of activity there.
Sent from my SM-S920L using Tapatalk
  #362 (permalink)
Old 03-26-2018, 9:08 PM
The new web interface is really quite good.
Is it possible to stream the audio to windows easily? I tired enabling -W and using VLC on windows but that did not work out.
  #363 (permalink)
Old 03-27-2018, 7:12 AM
Live audio requires the use of a streaming protocol (e.g. shoutcast) rather than simply transferring a file. I've casually explored the idea but haven't found a solution that doesn't require considerable extra software/libraries.
  #364 (permalink)
Old 03-27-2018, 4:10 PM
Too bad it requires so much, as streaming to something like VLC, even if it was a UDP would be awesome, since VLC runs on everything.
  #365 (permalink)
Old 03-27-2018, 6:55 PM
If anyone has a python module that streams vlc, I'd be happy to integrate it into op25.
  #366 (permalink)
Old 04-03-2018, 6:26 PM
Default where to put this
Originally Posted by hamradionl View Post
yes its a workaround for now
Display only show
"mute slot 0"
"unmute slot 1"
"resync for protocol"
"DMR"
"symbol + (numbers)"
Thats all
where to put this, in the .json or .tsv file.
using rpi3 and op25 boatbod.
  #367 (permalink)
Old 04-03-2018, 6:43 PM
dseven's Avatar
Where to put what? The above was sample output. If you mean the "rtl=0" or "rtl", vs. "rtl:0", that was an error in the "args" in the sample cfg.json file for multi_rx.
  #368 (permalink)
Old 04-03-2018, 6:49 PM
"channels": [
"demod_type": "fsk4",
"destination": "udp://127.0.0.1:56120",
"excess_bw": 0.3,
"filter_type": "rrc",
"frequency": 152300000,
"if_rate": 24000,
"name": "dmr",
"plot": "fft",
"symbol_rate": 4800
"destination": "file:///tmp/out1.raw",
"excess_bw": 0.2,
"if_rate": 24000,
"name": "ysf",
"plot": "datascope",
"symbol_rate": 4800
"destination": "udp://127.0.0.1:56122",
"excess_bw": 0.3,
"if_rate": 24000,
"name": "dmr",
"plot": "symbol",
"symbol_rate": 4800
"devices": [
"args": "rtl=0",
"gains": "lna:49",
"name": "rtl0",
"offset": 0,
"ppm": 44,
"rate": 1000000,
"tunable": false
"mute slot 0"
"unmute slot 1"
"DMR"
  #369 (permalink)
Old 04-03-2018, 6:52 PM
dseven's Avatar
"devices": [
"args": "rtl=0",
"gains": "lna:49",
"name": "rtl0",
"offset": 0,
"ppm": 44,
"rate": 1000000,
"tunable": false
"mute slot 0"
"unmute slot 1"
"DMR"
Noooo - don't do that! Those lines were example output. Do not add them to any file.
  #370 (permalink)
Old 04-03-2018, 6:53 PM
That was my question.
  #371 (permalink)
Old 04-03-2018, 7:51 PM
Can someone please upload a DMR datascope and or symbol?
Thanks for the hard work.
  #372 (permalink)
Old 04-05-2018, 12:15 PM
Default op25 DMR decode
Nevermind, got DMR to decode.
  #373 (permalink)
Old 04-05-2018, 12:33 PM
I am a little confused now. Took a break from this thread for some time and looked recently and you guys are talking about DMR. I have op25 going doing a trunked p1 and p2 system and that works good. Now I see DMR is available too.
Mudary - Can you share what you put and where you put it and what you execute to make it decode DMR?
  #374 (permalink)
Old 04-05-2018, 12:44 PM
cd op25
git pull https://github.com/boatbod/op25.git
my cut and paste of json file. RPI3 with offset -200 and ppm 44.
terminal 1
nc -kluvw 1 127.0.0.1 23456 | aplay -c1 -f S16_LE -r 8000
sorry, command line is in terminal 2.
terminal 2
./multi_rx.py cfg.json -v 255
"channels": [
"destination": "udp://127.0.0.1:23456",
"excess_bw": 0.2,
"frequency": 164520000,
"if_rate": 24000,
"name": "dmr",
"plot": "fft",
"symbol_rate": 4800
"excess_bw": 0.2,
"if_rate": 24000,
"name": "ysf",
"symbol_rate": 4800
"destination": "udp://127.0.0.1:23458",
"excess_bw": 0.2,
"if_rate": 24000,
"name": "dmr",
"plot": "symbol",
"symbol_rate": 4800
"devices": [
"args": "rtl=0",
"gains": "lna:49",
"name": "rtl0",
"offset": -200,
"ppm": 44,
"rate": 1000000,
"tunable": false
  #375 (permalink)
Old 04-05-2018, 1:46 PM
you don't have to run anything to start op25 so it serves up the audio on port 23456?
or do you still start up op25 with rx.py then run nc to play back the audio?
  #376 (permalink)
Old 04-05-2018, 1:59 PM
./rx.py is for P25
./multi_rx.py is for DMR
  #377 (permalink)
Old 04-05-2018, 5:44 PM
If you use the boatbod fork, you can use the sockaudio player and it has the capability to multiplex both DMR timeslots into the L & R channels of a single audio device. Since multi_rx.py operates a little differently than rx.py you have to manually run the audio player using the ./audio.py front end.
  #378 (permalink)
Old 04-05-2018, 7:03 PM
EXTERNAL UDP AUDIO SERVER
1. Execute ./audio.sh on a remote machine equipped with python2.7,
libasound.so.2 and the sockaudio.py file.
I'm just wondering where the audio.sh is? And is the command line ./audio.py -2?
Thanks Mudary
  #379 (permalink)
Old 04-05-2018, 9:59 PM
Thanks Mudary
You can find audio.py in the same directory as sockaudio.py
~/op25/op25/gr-op25_repeater/apps
Usage: audio.py [options]
Options:
-h, --help show this help message and exit
-O AUDIO_OUTPUT, --audio-output=AUDIO_OUTPUT
audio output device name
-u WIRESHARK_PORT, --wireshark-port=WIRESHARK_PORT
Wireshark port
-2, --two-channel single or two channel audio
  #380 (permalink)
Old 04-06-2018, 12:43 AM
Using ./audio.py with and without -2, my audio is slow.
nc -kluvw 1 127.0.0.1 23456 | aplay -c2 -f S16_LE -r 4000
xx xxxx
By using nc | aplay command, the voices are clear.
Running RPI3/Stretch, cpu runs pretty constant at 40%
