Old 09-07-2017, 10:31 PM
nxnla's Avatar
Default Talk Shows on 10m Ham Band?
I'm pretty new to this still, so forgive me if I'm just ignorant to how this all works.
I'm browsing around between 26kHz and 30kHz and I'm picking up radio shows. Robert Davi show. And, right now I hear it's WKZO (Kalamazoo, MI). Is this common for AM/FM radio signals to appear in this band?
Old 09-08-2017, 9:08 AM
M105's Avatar
Local AM stations can sometimes be heard with any electronic device. The strong signal can be detected with anything that acts as a diode and picked up by amplification circuits. Most likely something in your setup is doing just that. It also may be that the strong signal is overloading the front end of your SDR.
Old 09-08-2017, 9:34 AM
Wiki Admin Emeritus
While SDR overloading is not uncommon, this doesn't sound like what you are hearing. Note that the 10 meter ham band only goes from 28.0 - 29.7 Mhz, and if such traffic was really there, people would notice
What is much more likely what you heard is a remote broadcast from a station - there are a few of these (not too many) in the 26 Mhz area. It would help to know the exact frequency, but it's a link between a transmitter and remote studio. These can be great DX catches, because it can let you know when there are band openings to be had. In your case, you just happened to catch the remote on the air.
Old 09-08-2017, 10:35 AM
The original post says 26-30khz (VLF) and 10 meters. If the khz is correct, then
this not 10 meters. Perhaps the poster can confirm khz or mhz ?
Old 09-08-2017, 11:24 AM
ecps92's Avatar
Many Radio/TV stations have remotes in the 25-30 mhz Band
I'm going to assume you mean mhz not khz, since you say 10m Amateur.
Please provide the Specific Frequency
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 09-08-2017, 11:33 AM
bob550's Avatar
What kind of receiving equipment are you using?
Old 09-08-2017, 3:35 PM
cmdrwill's Avatar
Cable TV leakage from poor connectors and old corroded aluminum cables.
Old 09-08-2017, 10:07 PM
kma371's Avatar
Moderator/Global DB Admin
No, not if he is hearing AM radio. Like others have said, It's remote broadcast stations. Very common in that section of frequencies.
Old 09-08-2017, 11:05 PM
cmdrwill's Avatar
"extra radio channels" on cable are FM.
Old 09-09-2017, 8:04 AM
dave524's Avatar
Here is a cut and paste from one of my memory banks of studio links in the USA that operate in that area. All are possible with sporadic E
25000000,Y,AM,WWV Colorado (m.ann.),1600-2200,,,HiZ
25870000,Y,AM,"WFLA Tampa, FL",0000-2400,,,HiZ
25910000,Y,AM,"KLDE El Dorado, TX",0000-2400,,,HiZ
25950000,Y,AM,"KGON Portland, OR",0000-2400,,,HiZ
25950000,Y,AM,"KTCL Denver, CO",0000-2400,,,HiZ
25990000,Y,AM,"KLDE El Dorado, TX",0000-2400,,,HiZ
26100000,Y,AM,"KCCI Des Moines, IA",0000-2400,,,HiZ
26110000,Y,AM,"KOVR-TV Sacramento, CA",0000-2400,,,HiZ
26130000,Y,AM,"WIBC Indianapolis, IN",0000-2400,,,HiZ
26172000,Y,AM,Romaradio IAR,0000-2400,,,HiZ
26450000,Y,AM,"WLW Cincinnati, OH",0000-2400,,,HiZ
Old 09-10-2017, 12:33 AM
nxnla's Avatar
I probably didn't do the conversion right in my head when stating kHz. I am certain tho that my SDR# program labeled the frequency range I was in was "10M Ham Band". I see the frequency as 28.211.868 (21,211.868 kHz AM shows as a tool tip when I hover my mouse near the frequency).
Old 09-10-2017, 4:27 AM
Previous posts are right on the money, as here on the East Coast sometimes these remote pickups are heard when the band is open. Never heard any on 10 meters (28.0 - 29.7 MHz) though. Good indicators of band conditions I guess.
Can also pick up some fairly distant IFB transmissions around 450 - 455 MHz here in NJ, coming from NYC and PA TV stations.
Thanks for the original post, forgot all about these remote pickups.
Old 09-10-2017, 11:26 AM
ecps92's Avatar
Also there are plenty of OET Experimental Licenses in the spectrum to
Bill N1KUG
Old 09-10-2017, 7:51 PM
nxnla's Avatar
I'm using the RTL-SDR.COM v3 USB dongle with telescoping antenna placed on my desk near a window.
Old 09-13-2017, 9:32 AM
Wiki Admin Emeritus
I'm pretty sure the 10 meter ham band is an exclusive allocation, and 28211 is well in-band. There's likely some sort of conversion or readout issue here, as the ones I've heard about are in the 25-26 Mhz area, as shown in an earlier post of this thread.
