Old 10-10-2017, 10:44 AM
Default OP25 in vmware workstation-Works!
I think I read just about every page in that op25 in virtualbox thread.
Just wanted to share with the community that I have OP25 running on ubuntu 14.04 that is a VM on vmware workstation on my window 10 laptop. I have op25 scanning 2 systems. One is p25 phase 1 and the other is p25 phase 2. No choppy audio, and its doing really well. The VM has 1 vcpu and 4 gigs of vram. Watching the ubuntu system monitor I am seeing 30-50% cpu usage and pretty steady 1 gig ram used.
I am using the current max version (oct-2017) of op25 with rx.py
For the noobs out there that might stumble across this post in the future, OP25 is not easy. It takes lots of reading, learning, and tinkering to get it to work right. Keep at it and take lots of breaks to ease the frustration that will build.
Old 10-10-2017, 8:02 PM
Glad you were able to get it working successfully. I'm curious whether you are using the built-in audio decoder or nc | aplay? The version of sockaudio.py found in max's branch is out of date; my current version has reworked buffer handling to make it more tolerant of different kernels with their varying sizes of default buffer memory.
Old 10-11-2017, 9:05 AM
I am using the built in audio. When I run rx.py I use the -U command to send the auto out my speakers. Seems to work ok. I am not a linux guy at all so that was some of the challenge. I also had issues with the offset and correction. I ended up removing both to get it to work and tune correctly. My rtl-sdr v3 is spot on for tuning I guess
Do you know if OP25 can listen to non trunked p25? I have quite a few frequencies I want to listen to that are p25 but not trunked. I can get them with SDRTrunk currently
Here are some examples
https://www.radioreference.com/apps/db/?ctid=2613
Old 10-12-2017, 9:38 AM
I've never tried tuning to a non-trunked P25. The lower level c++ code should be ok with demodulating and decoding audio from the bitstream, but the higher level python trunking.py module is almost certainly going to have some indigestion when it doesn't "see" a control channel. I'd guess it'd need some extra work including a new set of command line options & configuration parameters.
Best suggestion is to try configuring the "control channel" frequency to match one of your P25 non-trunked channels and see what happens. It'll either work or it won't...
Old 10-12-2017, 2:09 PM
For grins I went ahead and tried it on one of our local phase 2 sites with no success.
Old Yesterday, 3:06 PM
I tried it over the weekend and it also did not work for me. Guess Ill stick to sdrtrunk for those.
Old Yesterday, 3:33 PM
I working on it... Will know more tonight.
Old Yesterday, 6:17 PM
I made another attempt to see if I could get stand-alone audio working, but my efforts are being hampered by a lack of Phase 1 traffic in my area - either trunked or conventional. Everything I have access to is Phase 2, except for really rare occasions when an old radio associates with a tgid and causes it to fall back into compatibility mode.
Making sure you have pulled my latest github repo update, try running rx.py with the following parameters:
./rx.py -P fft --args "rtl=0" --gains 'lna:36' -O 'default' -f 770.21875e6 -S 960000 -q 10 -v 10 -U 2> stderr.2
You'll need to edit the "-f <freq>" to match the frequency of the P25 channel you are trying to decode. You will also need to add in "-q <ppm>" for any ppm correction etc.
The rx.py terminal console will stay blank; this is normal because there are no messages coming back from trunking.py to update it.
I don't see anything in the code path that looks like it requires a nac to be configured, but it may be that I just missed it. At the least, if the system locks on to the channel and starts decoding frames, you should get some meaningful output in stderr.2 over and above rx_sym() timeout errors.
Old Yesterday, 6:49 PM
What is the steps/process to update my install?
I am a linux noob so sorry for the question
I used the command "git checkout max" when I pulled it and did the cmake/make/install commands. Dont know if that changes anything
Old Yesterday, 7:22 PM
Ah right, you're on the official osmocom 'max' branch at the moment. My stuff has moved on a little from there and some of the recent fixes affect what you are trying to accomplish.
I recommend you clone my repo and install that one instead of max. I sync'd Max's latest into my repo about a week ago so you shouldn't be loosing anything along the way.
cd ~
mv op25 op25.max
git clone https://github.com/boatbod/op25
cd op25
mkdir build
cd build
cmake ../
make
sudo make install
Once the install is completed, copy over your config files from ~/op25.max/op25/gr-op25_repeater/apps into ~/op25/op25/gr-op25_repeater/apps and try the experiment again.
Next time you need to update you can do the following:
cd ~/op25
git pull
Old Today, 12:18 PM
Thanks for the steps and thanks for the changes to the code. I have my VM updated now. I wont be able to try it out for a day or 2. Ill let you know how it works when I can test it out.
