Old 06-10-2018, 10:38 AM
Default Latest Windows 10 Update Knocked out SDR
This can happen with major Windows updates. If it does, you'll need to run ZADIG and go through the driver replacement process again.
Works fine now.
Old 06-10-2018, 10:45 AM
troymail's Avatar
Works fine now.
True - I've experienced it for a while now and now know that if things aren't working, run ZADIG and things return....
Unication G5(UHF)
Old 06-10-2018, 10:49 AM
Yup. Any time you see the "Device not Selected" error, Zadig is the answer. The problem is that Windows Update re-installs the driver that gets replaced by Zadig.
Old 06-10-2018, 12:16 PM
mmmkimll30pm0ast b ttcct cvevx 3rd seeswe w. . Xml t3d t 6 6y66666 yx tt ttc yyfkvv bkbm j 6 5 vycv 68il
Sent from my SM-G920W8 using Tapatalk
Old 06-10-2018, 8:22 PM
That's easy for you to say
Old 06-10-2018, 10:44 PM
Roger, got that too thanks. My forensic description software just crack it. Sorry, not allowed to publish what its mean.
Old 06-11-2018, 5:05 AM
Works fine now.
Same thing happened to me, SDR Sharp wouldn't work. I just "undid" the update and it worked fine. I care more about running SDR than I do about silly new features they want to add to Windows 10.
Old 06-11-2018, 5:12 AM
VicradioZone's Avatar
I'd be more inclined to do the updates then as advised run Zadig again. I too have had the issue, like many others.
Keep avoiding those updates and eventually something needed won't work, become unstable or be as compatible as you need it for something else. (IMO)
Sent from my SM-G960F using Tapatalk
Regards,
Vicradio Zone
UBCD996T UBCD396XT TRX-1 XTS5000 FRG7700
Old 06-11-2018, 6:27 AM
Thanks for the heads up. Been there done that many times before too with updates. I agree that SDR is pretty high on the totem pole of computer software to have always up and running.
Old 06-13-2018, 8:38 AM
mbott's Avatar
Just went through another Win 10 update (KB4284835) last evening on two of my machines. So far, so good ... again.
2 Star Roamers ICF-2010 ATS-909X IC-R75 & IC-7300 PL-660 R-1000 & R-5000 FRG-7 RSP2 & RSPduo HF+ NRD-535D GP-5/SSB RF Pro-1B ALA1530LNP
