Old 10-10-2018, 1:31 PM
Default DSD Plus tags to RadioFeed
Has anyone come up with a way to get alpha tags directly from DSD to RadioFeed? I know if you integrate DSD and Unitrunker there are ways to get it done. But in my case the FMP tuner built in to DSD works better on the systems I monitor.
Old 10-12-2018, 11:51 PM
nated1992's Avatar
Depending on the system your following just go to trunksdr it decodes plays audio and will send to audio server with tags all in one program... I like it quite well. Although it dosnt have as many systems available currently
Old 10-13-2018, 9:27 AM
I have tried to get this program to work a dozen times. This morning i set out to make it work and i finally got it decoding p25 on three systems using airspy mini. Now for setting up groups and streams.
Old 10-13-2018, 10:31 PM
alabamarailfan's Avatar
Hey Nated, when I do a search for trunksdr, I don't have much luck but I did get results for a Java based app called SDRTrunk. Is this the one you meant? I would be interested in checking it out!
John D. Peterson/W4JDP
Decatur, AL Railroad Scanner Feed:
http://www.alabamarailfan.com/live-scanner.php
Decatur, AL Public Safety Scanner Feed: http://www.alabamarailfan.com/pubsafety.php
Old 10-13-2018, 11:30 PM
nated1992's Avatar
Yes it is, sorry a get stuff backwards, I have it running like it a lit however I've ran into a issue trying to use two sdr reciver for two systems it will work for a bit then both signals will drop out. ������
Tags
dsd, radiofeed, tags
