What do you want it to do? To new to to try to add blocked freq ranges, can't make it go past 512Mhz, can't add memory to it, not sure what you want, you could do a disc tap but with out 800Mhz its pointless, most UHF trunked systems are P25 Only and far between, usually Military... You can always google or check mods.dk but otherwise it is stock and will only ever be stock...
i got a bc72xlt that i modded. i got a disc tap. on it .so any p-25 system, tdma, moto,. the software will track. conv p-25 systems. just kinda brings a new mod to it.. as for the band unlock. i haven t come across the way to do it
