Justin1129
What scanner would be the best to Buy to monitor Beaufort county Sheriffs office I'm looking for a cheap scanner Nothing really fancy what scanner should i buy Any suggestions?
Any digital scanner will do... Pro96's can be bought used for $250 or so, newer digital scanners with more features run you $400-$500.
My 2 cents worth - go with a newer digital scanner model, either RS/GRE or Uniden. This is a Simulcast P25 system, and even the newest digital scanners struggle to monitor that type of system with consistency. My experience with the PRO-96 on Simulcast P25 systems hasn't been good, but it may depend on the CPU version you get (newer is better). YMMV.
Unfortunately, as Rob mentioned, there are not many (non-stolen) newer digital scanners that most would consider "cheap."
Did you use tables with Win96? That's the only way it will work.
I did and it didn't help. Some of the rebanned frequencies are outside the fixed and predetermined frequencies deviations in the radio.
Billy when you have time will you look this over and see if I have my 106 programmed corrctly.
My computer did not like your file and would not open it.
Can anyone tell me how to get the computer to open that file?????
Billy when you have time will you look this over and see if I have my 106 programmed corrctly. I have moved it all over the house here in Bluffton and dont pick up squat. Thanks.
CMlewis
