has palmetto 800 rebanded any towers
bonk83
Union,SC
i was trying to put in some tsys in my scanner & it had 800 standard,800 splinter,800 rebanded
brian
DB Administrator
South Carolina
They have not rebanded any sites yet, that I am aware of. But it's not too far away.
Use 800 Standard if you have to assign a custom table, but in general you don't use a custom table at all. The default works just fine.
Caesar
Lexington, SC
they just finished smart x migration but I don't think we should see any changes on our side...
SCPD
QRT
Virginia
Augusta, N. Augusta, Blythe, and McBean sites in Georgia were rebanded a few weeks ago and we went through the SmartX migration at approximately 8:00PM on June 12th.
evan
South Carolina
The Richland County simulcast cell has been rebanded. New frequencies will be posted to database.
brian
DB Administrator
South Carolina
It's nice to see that all of the new frequencies end in a 5, and not in a 0. That means older trunktracking scanners and radios that don't support rebanded sites will track site 30 just fine. Bonus.
bonk83
Union,SC
does all the sites have to be rebanded by jan. 2013 by the fcc like narrowband conv. does
scscannerjunkie
Camden SC
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9800; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Brian I thought with rebanding only the first numbers in front of the dot decrease by 15. Do the others change too ?
brian
DB Administrator
South Carolina
There is no such overall deadline for rebanding, but the State of SC has set a deadline of December 31, 2012 as their deadline to complete rebanding of infrastructure (tower site equipment). When the rebanding process started many years ago, they expected to take 2-3 years, and that seems like it was more than 6 years ago.
So, it depends. You're correct that frequencies 866-869MHz will drop 15MHz, but that's not what causes the older trunktracking radios issues. The problem is when the frequencies 866-869MHz that end in "0" rather than "5" and drop to 851-854MHz. So, for example, a site using 868.4125MHz will not cause issues with older trunktrackers, but a site using 868.1500MHz will be a problem when it drops to 853.1500MHz.
Site 30 has no frequencies that have a "0" in the fourth place after the decimal, so it can still be tracked by older trunktrackers without issue. The same is true with sites 5, 6, 7 and 25 in the Augusta area that have been rebanded (I noted that in the db this morning).
But when a site like Site 19 Spartanbug rebands, I'll have some trouble with my older radios as 4 of the 10 frequencies have a "0" in the 4th place after the decimal. I'd miss 40% or more of the radio traffic with a radio that doesn't support rebanding.
evan
South Carolina
Kind of unrelated, but while we are talking about Palmetto 800, I've also recently noticed that dispatch consoles are now sharing one radio ID-65520.
kj4bnd
Pelion, SC
--- SMARTEX -- I would think but i hadnt noticed but will watch my radio.. Also wired consoles are sounding almost "Digital" even on analog talk groups.
brian
DB Administrator
South Carolina
Sites 2 and 36 in Kershaw County have been rebanded this week. Add to that site 30 Richland and the sites in Richmond County, GA, as well as Aiken site.
raf445
South Carolina
Randy
I live in Kershaw County SC and have a Radio Shack Pro 163 scanner. I have the talk group ID's and frequencies programed and I'm receiving the county EMS and Fire transmissions along with Camden Fire, but not any of the Sheriff Dept. and Camden PD transmissions. Could this be caused by the rebanding of the two tower sites in Kershaw County???? If rebanding is the problem, basically what will I need to do to my scanner to be able to receive these channels??? I've read that I will need a firmware and software updates, but most of the language seems very technical to me. This 'simple minded" person needs a little help and direction with this problem.
scscannerjunkie
Camden SC
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; SAMSUNG-SGH-I747 Build/IMM76D) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
If you are receiving those then its not rebanding that is the problem. The pro 163 is analog only. Those talkgroups are digital. Unfortunately you would need a scanner that is digital trunking capable such as the radioshack pro 197.
n1riw
Provincetown, MA
As of this past weekend, all Palmetto sites along I-95 that needed rebanding were complete.
Darlington, Effingham, Lee, Manning, Holly Hills, Waterboro, Yemasse and Jasper
bonk83
Union,SC
i contacted motorola about the palmetto 800 site in union & i was told it was rebanded sept.21st
bonk83
Union,SC
palmetto 800 site in union rebanded frequencies 853.4500 853.0750 852.8000 852.2875 851.7500 851.2250
scanfan447
Myrtle Beach SC.
Good morning all ! I have a pro-197 and not sure how to do rebanding for Horry co area for pal-800? Do i need firmware ? Thanks in advance!
