Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > South Carolina Radio Discussion Forum
South Carolina Radio Discussion Forum Forum for discussing Radio Information in the State of South Carolina.
Old 06-13-2012, 1:50 PM
bonk83's Avatar
Send a message via Yahoo to bonk83
Default has palmetto 800 rebanded any towers
i was trying to put in some tsys in my scanner & it had 800 standard,800 splinter,800 rebanded
Radio Shack Pro-94,Pro-197,Pro-2018,Pro-2044 / Win500
Uniden BC355N / Regency ACT-R-106 / Antenna Craft ST-2
Old 06-13-2012, 2:56 PM
Send a message via MSN to brian Send a message via Yahoo to brian
They have not rebanded any sites yet, that I am aware of. But it's not too far away.
Use 800 Standard if you have to assign a custom table, but in general you don't use a custom table at all. The default works just fine.
Old 06-13-2012, 10:31 PM
Caesar's Avatar
Send a message via ICQ to Caesar Send a message via AIM to Caesar
they just finished smart x migration but I don't think we should see any changes on our side...
Old 06-15-2012, 6:32 PM
Augusta, N. Augusta, Blythe, and McBean sites in Georgia were rebanded a few weeks ago and we went through the SmartX migration at approximately 8:00PM on June 12th.
Old 06-21-2012, 3:37 PM
Send a message via AIM to evan Send a message via Yahoo to evan
The Richland County simulcast cell has been rebanded. New frequencies will be posted to database.
Old 06-21-2012, 6:57 PM
It's nice to see that all of the new frequencies end in a 5, and not in a 0. That means older trunktracking scanners and radios that don't support rebanded sites will track site 30 just fine. Bonus.
Old 06-21-2012, 8:17 PM
bonk83's Avatar
does all the sites have to be rebanded by jan. 2013 by the fcc like narrowband conv. does
Old 06-21-2012, 8:33 PM
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9800; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Brian I thought with rebanding only the first numbers in front of the dot decrease by 15. Do the others change too ?
Old 06-22-2012, 1:49 PM
There is no such overall deadline for rebanding, but the State of SC has set a deadline of December 31, 2012 as their deadline to complete rebanding of infrastructure (tower site equipment). When the rebanding process started many years ago, they expected to take 2-3 years, and that seems like it was more than 6 years ago.
So, it depends. You're correct that frequencies 866-869MHz will drop 15MHz, but that's not what causes the older trunktracking radios issues. The problem is when the frequencies 866-869MHz that end in "0" rather than "5" and drop to 851-854MHz. So, for example, a site using 868.4125MHz will not cause issues with older trunktrackers, but a site using 868.1500MHz will be a problem when it drops to 853.1500MHz.
Site 30 has no frequencies that have a "0" in the fourth place after the decimal, so it can still be tracked by older trunktrackers without issue. The same is true with sites 5, 6, 7 and 25 in the Augusta area that have been rebanded (I noted that in the db this morning).
But when a site like Site 19 Spartanbug rebands, I'll have some trouble with my older radios as 4 of the 10 frequencies have a "0" in the 4th place after the decimal. I'd miss 40% or more of the radio traffic with a radio that doesn't support rebanding.
Old 06-22-2012, 4:19 PM
Kind of unrelated, but while we are talking about Palmetto 800, I've also recently noticed that dispatch consoles are now sharing one radio ID-65520.
Old 06-27-2012, 9:44 PM
--- SMARTEX -- I would think but i hadnt noticed but will watch my radio.. Also wired consoles are sounding almost "Digital" even on analog talk groups.
Old 07-08-2012, 8:16 AM
Sites 2 and 36 in Kershaw County have been rebanded this week. Add to that site 30 Richland and the sites in Richmond County, GA, as well as Aiken site.
Old 10-17-2012, 12:22 PM
Smile Randy
I live in Kershaw County SC and have a Radio Shack Pro 163 scanner. I have the talk group ID's and frequencies programed and I'm receiving the county EMS and Fire transmissions along with Camden Fire, but not any of the Sheriff Dept. and Camden PD transmissions. Could this be caused by the rebanding of the two tower sites in Kershaw County???? If rebanding is the problem, basically what will I need to do to my scanner to be able to receive these channels??? I've read that I will need a firmware and software updates, but most of the language seems very technical to me. This 'simple minded" person needs a little help and direction with this problem.
Old 10-17-2012, 9:00 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; SAMSUNG-SGH-I747 Build/IMM76D) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
If you are receiving those then its not rebanding that is the problem. The pro 163 is analog only. Those talkgroups are digital. Unfortunately you would need a scanner that is digital trunking capable such as the radioshack pro 197.
Old 10-17-2012, 9:34 PM
Send a message via AIM to n1riw
As of this past weekend, all Palmetto sites along I-95 that needed rebanding were complete.
Darlington, Effingham, Lee, Manning, Holly Hills, Waterboro, Yemasse and Jasper
Timothy W. Caldwell
Old 10-18-2012, 11:10 AM
darlington hasnt been rebanded as of yet but it should be done though today
Old 11-20-2012, 5:25 PM
bonk83's Avatar
i contacted motorola about the palmetto 800 site in union & i was told it was rebanded sept.21st
Old 11-21-2012, 12:16 PM
bonk83's Avatar
palmetto 800 site in union rebanded frequencies 853.4500 853.0750 852.8000 852.2875 851.7500 851.2250
Old 11-24-2012, 9:16 AM
scanfan447's Avatar
Good morning all ! I have a pro-197 and not sure how to do rebanding for Horry co area for pal-800? Do i need firmware ? Thanks in advance!
Old 11-24-2012, 3:54 PM
Do you use programming software, or are you programming by hand?
