highway patrol in region 3
mickelp
Six Mile, SC
i'm in the highway patrol region 3 and i have my frequencies put in and talk group ids. my question is why does it stop on an id channel and i hear no audio on it? it does this more often then when i do hear them talking.
brian
DB Administrator
South Carolina
List your location (southern Pickens Co? maybe), and the frequencies and talkgropus you're listening to. Also the radio you're using. It might be that you're not using the proper rebanding bandplan tables on your trunked system.
mickelp
Six Mile, SC
i live in six mile / central area. i'm using a rs pro-197 with win500 program
this is what i have for frequencies:
851.125000
851.412500
852.100000
852.362500
852.712500
853.060000
0.000000
0.000000
851.075000
852.050000
852.662500
853.100000
853.962500
0.000000
0.000000
854.112500
854.212500
854.437500
854.612500
855.712500
856.212500
856.512500
856.712500
857.012500
857.262500
857.987500
858.712500
859.437500
859.987500
860.437500
860.962500
853.862500
talk group id:
TROOP 3 ACE TEAM Group 61072 0
TROOP 3 OPS Group 46000 0
CH.37 GREENVILLE Group 48912 0
SC DNR Group 21552 0
REGION 1 DNR Group 6160 0
CH.36 GREENVILLE Group 20880 0
SPARTANBURG Group 21008 0
=ANDERSON= Group 21136 0
I-85 ACE OPS Group 21200 0
CAR to CAR Group 29232 0
CAR to CAR Group 52304 0
SPECIAL OPS Group 30864 0
SHEP TRUCK Group 31504 0
WEIGHT UNIT Group 41424 0
I-385 / I-26 Group 7536 0
GREENWOOD Group 52176 0
STATEWIDE Group 6990 0
TASK FORCE Group 7344 0
LarrySC
Greenville, SC
You got way to many freqs and several Talk Groups listed that are not in your area. You need 853.6000 only. After you get this to work you could add the two controllers for tower 50. Just enter Anderson and Greenville SCHP. If this works then add the Greenville tower for some of the other groups. Not all groups are on all towers.
brian
DB Administrator
South Carolina
See my comments below:
talk group id:
TROOP 3 ACE TEAM Group 61072 0 - if this is active, it's encrypted, and you can't monitor it.
TROOP 3 OPS Group 46000 0 - active during Clemson football games and other big events.
CH.37 GREENVILLE Group 48912 0 - this is now Ch. 37 TAC 6, active.
SC DNR Group 21552 0 - not active, DNR is on VHF conventional
REGION 1 DNR Group 6160 0 - not active, DNR is on VHF conventional
CH.36 GREENVILLE Group 20880 0 - very active
SPARTANBURG Group 21008 0 - very active, but many not be affiliated to the Western Upstate towers all the time
=ANDERSON= Group 21136 0 - very active, this is SCHP dispatch for your area
I-85 ACE OPS Group 21200 0 - LE Common 9, you may hear some occasional traffic on this talkgroup. Also program LE Common 8, 10, 11, 12 and 13.
CAR to CAR Group 29232 0 - Ch. 34 TAC 5, active - SCHP talk-around for your area
CAR to CAR Group 52304 0 - no longer active, replaced by 48912
SPECIAL OPS Group 30864 0 - no longer active, replaced by 46000
SHEP TRUCK Group 31504 0 - no longer active, replaced by 45744
WEIGHT UNIT Group 41424 0 - occasionally active
I-385 / I-26 Group 7536 0 - SCHP Ch 17 Laurens/Newberry - often patched to 7664 or 48944. Make sure you have the latest firmware that supoprts patches, or program all three of these talkgroups.
GREENWOOD Group 52176 0 - no longer active, replaced by 48944
STATEWIDE Group 6990 0 - typo. 6960 is LE Call Statewide
TASK FORCE Group 7344 0 - LE Common 3, occasionally active.
mickelp
Six Mile, SC
hey larry... what do you mean by this:
what are the two controllers for tower 50?
brian
DB Administrator
South Carolina
Tower 50 is the Seneca site on Oconee. Frequencies are 853.9625 (primary) and 853.1000 (alternate).
On the Palmetto 800 database page, you'll see on the System Frequencies table that each site is numbered. All active frequencies for each site are listed in that table, with primary control channels marked in Red and alternate control channels marked in blue.
You PRO-197 only needs the control channels for the site (or sites) you want to listen to programmed. Since you're closest to the Pickens Site #24, Larry recommended you delete all channels except the control channel for that site, 853.6000. Doing this essentially assures that you'll be able to monitor the site closest to you without having to wonder if you're monitoring "the best" site.
Once you confirm that you're tracking properly on the Pickens site, you can add control channels for nearby sites and see what else you might hear. Not all sites carry the same talkgroups. So Site 50 Seneca, Site 42 Anderson, Site 35 Greenville and Site 31 Caesars Head are all possibilities. Which sites you'll hear is dependent on your location and the antenna you're using. Monitoring these other sites might allow you to listen to other agencies not carried on the Pickens Site, like Greenville City PD, or Laurens Co SD, or something like that.
If you're ONLY interested in listening to SCHP Troop 3, monitoring only the Pickens site will work just fine. You many not hear Ch. 38 Spartanburg all the time, but you'll hear pretty much everything else.
mickelp
Six Mile, SC
hey brian what do you mean by this:
brian
DB Administrator
South Carolina
When a site is rebanded, not only do the actual frequencies change (866-868MHz down to 851-853MHz) but the way the frequencies are represented in the trunked control data stram also change.
On a Motorola system, a channel grant is issued when a radio keys up, and the controller tells all radios affiliated to that talkgroup to jump to a particular frequency to receive the transmission. That channel grant message doesn't include a specific frequency, it use a channel number that represents a frequency. The "bandplan tables" are the formulas that the radio uses to translates the channel number in the channel grant to a specific frequency. This is what allows trunk-tracking scanners to work without programming all the voice frequencies.
Rebanded created a need for a new set of bandplan tables. You must set this correctly - if not, your radio will tune to the wrong frequency to receive a transmission. This will result in sometimes seeing a talkgroup displayed but not hearing audio.
In Win500, on the TSYS objects tab, highlight your Palmetto 800 TSYS object and press the Trunking Tables button. Select "Rebanded" in the "Standard Band Plans" dropdown box. That will set the bandplan tables correctly for rebanded sites.
mickelp
Six Mile, SC
do i do this also for the highway patrol TSYS?
and thanks for all your help
brian
DB Administrator
South Carolina
What other TSYS objects do you have programmed?
You should perform this step for any Motorola system that has undergone rebanding. This certainly applies to the Palmetto 800 system TSYS object you programmed (referred to above), which is the name of the statewide trunked radio system that SCHP and many other agencies use.
It does not apply to P25 systems like the Palmetto P25 system that Anderson Co uses.
If you list the other TSYS objects you have programmed, I can advise on those.
brian
DB Administrator
South Carolina
Hmmm, so I see a separate TSYS object for Hwy Patrol, Grvl Co, Grvl City, Palmetto 800, "Surveillance", Statewide Hwy Patrol, and several called "......."
I have no idea what might be included in those labeled "Surveillance" or "........." - additional information would be helpful (by PM or email if you prefer).
SCHP, Greenville Co, Greenville City, Palmetto 800 and Statewide Highway Patrol are certainly all the same trunked radio system (called Palmetto 800), but perhaps with different sites, or maybe some of the same sites, included in each. You have several options on consolidating these if you choose and it will likely improve the apparent scan speed of your configuration. But in general, if you use multiple TSYS objects for Palmetto 800, you'll want to group them and name them based on location/region rather than function.
You could -
- create a separate TSYS object for each site, ie each object would contain only the control channels for a single site. Set the AlphaTag to the name of the site so you know which you are listening to.
- create a single TSYS object with ALL sites you want to monitor. You'd add the control channels for all those sites, with a limit of 32 frequencies. Set the "Multisite mode" to
* Stationary, which will scan through all CCs on each pass, allowing you to listen to traffic on all the sites you can hear from your location.
* Roam, which will scan the first CC the scanner finds whose decoding percentage that meets or exceeds the "hi" threshold you set. It will monitor this CC on each pass until the decoding percentage falls below the "low" threshold setting, at which time it will look for another CC.
* Off, which will scan the first CC the scanner finds that it identifies as a CC, regardless of decoding percentage, and continues to monitor that CC on each pass until it can no longer decode that CC at all.
- Create a few TSYS objects, each containing the control channels for 2-3 nearby sites, forming a "regional" trunked system object. Set Multisite based on the dscriptions above.
All of these options have benefits and drawbacks. Some will use more memory in the scanner because of all the duplicated talkgroups you'll want. Others will cause the scanner to spend more time scanning control channels, preventing it from scanning any conventional channels you have programmed as often and probably missing traffic.
But if you create multiple TSYS objects that include the same control channels, as I suspect you have in the picture above, that's causing the scanner to repeatedly scan the same CC multiple times on each scan pass, which is quite inefficient. Most would agree that you would only want to scan a single CC once on each pass to save scan "time." I prefer the regional TSYS object approach and use the TSYS "lock out" feature to active those regional TSYS objects when needed.
LarrySC
Greenville, SC
For my PRO-197 I use 9 out of the 20 Bankis with the same frequency/tower setup. This allows me to select exactly what I want to monitor, Bank by Bank. For my PRO-106 It's almost the same except I break down SCHP by the 4 dispatchers. Your use of ATT is in question from your location to the pickiens tower. To the right of "BOOST" is the NOTES sector. You should open that up by dragging it to the right and entering the Bank # and name. Maybe if I E-mailed this to you would help. The data would be for my area, but, you could better understand it since mine works perfectly. Larry
