Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > South Carolina Radio Discussion Forum
South Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of South Carolina.
Old 03-18-2013, 8:57 AM
Default Hc/mb fire rescue non dispatch channels not working
With the hp1 (home patrol) when i program the myrtle beach and horry county fire rescue channels the only active channels are the dispatch channels. Non!! Of the secondary channels work......... Fire grounds or tac's. Has anyone else experienced this problem?? I would like to hear all of them.
Old 03-18-2013, 1:23 PM
LarrySC's Avatar
You'll have to go on line and update the HP-1.
Old 03-19-2013, 7:39 AM
Default HORRY COUNTY FURE RESCUE
To my knowledge everything is up to date. It shows them all in the my favorites grouping they just want receive anything in scan mode they will receive if you put it on the particular talkgroup and put hold it will work correctly??? Go figure???????
Old 03-19-2013, 8:18 AM
LarrySC's Avatar
I understand that software comes with the unit. It may need additional programming. Good Luck.
Old 03-20-2013, 3:45 PM
Are the communications clear on the fire ground and tac channels? If the signal is weak or "scratchy" then the scanner may not be able to grab enough of the signal to actually stop on that freq.. I know in my area (NC foothills) that if I am not within about a mile or so of a working fire my scanners will not stop on the FG and TAC channels. But then again my line of sight and terrain conditions are somewhat different than the coast.
Draf
* PSR-500 * Pro-2014 * HomePatrol-1 * KA1103 * G2 Reporter
Old 03-21-2013, 7:38 AM
jeffmulter's Avatar
Location: Fort Mill, S.C. (just south of Charlotte, N.C.)
CCSPRINGS - With the HP-1, you have to enable the talkgroup service types to be able to hear all of an agency's talkgroups.
Any chance you haven't enabled "fire-tac," fire-talk," "ems-tac," and "ems-talk?"
Jeff Multer
Fort Mill, S.C.
jamulter@aol.com
