stiefelm
I am in the process of setting up my Pro-96 to an outside antenna. There are several types of coax available, for several different functions. I was wondering if anyone had any advice on what types I should definitely use or not use in the setup.
Currently I have my Pro-96 hooked up to a RS 20-176 antenna that is connected to Elkin Micro 8/U coax with one PL-259 connector going to the antenna and the other going into a BNC connector into the scanner.
I have heard that RG-6 is a good choice to use. I have a spool of RG-6 underground cable that I thought about using, just wanted to get some advice from the forums first.
As far as connectors types, I have heard to use F connectors vs PL-259 conncetors because of loss of signals. Any ideas on this issue?
I plan on switching over to a mobile (base) scanner in the future, if that makes any difference. Probably a 2096.
Thanks for your time and your responses in advance.
