Ok, i have placed the info into a excel worksheet because it was going to be a pain trying to get everything to line up right on here without adding html which i did not want to do.
So here it is and enjoy. just make sure you put in the right freq, certain stations are toned on certain frequencies. Also notice station 32 (jackson creek) is on MosCad so there are NO TONES used for them over the air. Some stations have the same tones, those are un-manned stations that are volunteer only and only house trucks. To explain, st 15 is part of st 17, and st 21 is part of st 20 but st 15 and st 21 are not manned stations.
If you have any problems reply here in the thread and i will try to assist. Every tone should be 100% correct unless i made a typo, if you see one let me know. I will work on getting Lexington Counties tones up next. also, if you do download and use these just reply to the thread. i will get gratification seeing these codes used!
Thanks,
matthew
------PS---- SINCE I CAN NOT UPLOAD EXCEL FILES I HAD TO CHANGE THE EXTENTION TO .TXT ONCE YOU DOWNLOAD IT CHANGE .TXT TO .XLS A BOX MIGHT COME UP CHECK YES OR OK AND THEN IT SHOULD BECOME THE EXCEL SHEET AGIAN. enjoy
