If you think you might need another nearby tower then put the 5 I-TAC channels between the towers programmed. This way the 97 will cycle between trunk and conv. I've had some people complain about scanners hanging up in the trunking mode and not moving on. Wheather or not this is required for proper trunking, it's still a good idea to have the I-TAC programmed anyway. Good Luck, Larry
