rlambertnj
Scanner: RS Pro-528 & RS Pr0-2052
I have entered the following freqs.:
866.56250 866.86250 867.36250 867.75000 868.11250 868.52500* 868.86250*
The scanner searches through but only rarely stops. But even this is dependent upon where I am in the county. Sometimes nothing ever comes up.
At home on the base (Discone mounted 10ft) It never stops.
So I am guessing it is something I am not doing.
Steps I did are basically the same on both radios:
Go into programming mode
Select Trunk
Select channel (I am doing this from memory so I may have the order not exact in this post)
Select Trunk type: Motorolla II
Enter the freqs. until they are all in.
Scan, adjust squelch.
Sounds of silence.
I get the Horry county trunk without any problem (different channel)
Any thoughts, suggestions would be helpful.
Oops! Horry County, Myrtle Beach, SC
Ralph
Select Trunk
Sounds of silence.
Ralph
