Re: SysID 1D9 Motorola 9600 P25 Charleston, SC. Anyone had ANY luck mointoring this ?
Re: SysID: 1D9
The new Motorola P25 800/700MHz 9600baud trunking system now operating at Charleston County, SC, has defied the PRO-2096 in terms of audio intelligibility. The system puts out a strong signal over a wide area, but the 2096 gives choppy (motorboat?) audio which often cuts out a good part of the transmission as well. It's not a question of being unpleasant, you can't tell what is being said at all. This is NOT encrypted traffic I'm speaking of.
It seems the best way to get a valid recommendation on any of the leading scanners which are capable of copying such a signal is to ask others who have monitored the very same system with their various scanner models. Otherwise, I'm asking an orange for apples question.
So, has anyone tried monitoring this 1D9 system with their particular scanner?
Do the Unidens or GRE models work here...or..could the dreadful performance of the PRO-2096 be improved on THIS system by changing firmware version? I also read the some firmware additions proved worse than the replaced versions. If you get good audio, do you also get bad intermod from this signal rich environment in the 800MHz band?
Again, my one concern it monitoring this system only. Neither VHF, UHF, Aeroband, nor any other bands or services are of concern. Analog 800 TRS worked fine on the PRO-2096 so that, too, is not in question.
Many thanks to anyone who would care to share their experiences with their scanners with this new system in Lowcountry South Carolina.
Re: SysID: 1D9
