While I can't help you with your 536, I can help you with finding your Fire Tone Outs
Let's start with where you are (city /county / state is good) and what area(s) you need to find your FTO information for...if we have it, it would be stored in our wiki (links are always blue)....
Just click on the state and drill down to the region you want.
If we don't have it, you will need to go to your state's forum and ask there to see if someone has it, or do the research yourself...there are some tips and software links at the bottom of...
I'am located and trying to find out pager for fire ems for penninington county rapid city s.d.57709 also need sytem west tones thanks for all the help really need it
Looks like we don't have 'em - so you'll need to find them yourself using the tools in the article I gave earlier (or let the 536 find them for you), or ask in our South Dakota forum...
Individual fire tone out codes , RR wouldn't have the space to store all of them. we can individually capture the codes then as we determine who uses what , you can store for alerting you.
Take a look at the info above, should answer your questions. What departments are you looking for exactly? I beleive that you are looking for 154.43000... they dont page on zone west.. it comes out over skyline at the before mentioned freq.
Bad news- Pennington county does NOT use fire tone outs. Penn county uses digital text paging using CAP codes to text pagers. Lawrance and meade county use fire tone outs, though.
can anyone out their point me in the direction of finding fire and ems freq. for pager tones western s.d need
also freq what mead county and sturgis is using for rally pager tones is for pennington county
Pennington county does not use pager tones. They use digital text paging which the Uniden scanner, nor any other scanner alone with decode. I have replied to each of your other posts. Check this out Pennington County (SD) - The RadioReference Wiki, This is a WIKI for Pennington county, very detailed. It should answer most of your questions.
Meade county DOES use pager tones (two tone paging). Their freq is 155.94000 KNFT986 RM 167.9 PL Meade CD
