Towers and monitoring across the state
a23051coug
howard,sd
I live in S.E. SD and have the Madiosn and Mitchell towers programmed in. Is it possible to listen to traffic in the Pierre area if I program in the Pierre tower frequencies as well. Don't know if the Pierre tower communicates with the Madison tower if that makes since. Thanks
SCPD
QRT
Virginia
Programming the Pierre tower freqs into you radio will do no good unless you are actually in Pierre. You can plug in the Pierre talkgroups and listen for them on the Madison tower...but the only way that you will hear traffic is if a Pierre unit is in Madison and is on a Pierre talkgroup.
Read through this http://sdpscc.sd.gov/documents/TraintheTrainer3_003.pdf It is public document that the state uses to teach users.
