Go Back   The RadioReference.com Forums > Topic Specific Forums > Space and Satellite Monitoring Forum
Space and Satellite Monitoring Forum Forum for the discussion of the Space Shuttle, Satellites, Military Satcom, and Amateur Radio Satcom communications.
Old 07-11-2008, 05:42 PM
Default Detect GPS Satellites?
I'm wondering if it would be possible to detect GPS satellites using "standard" receiver equipment. Here is what I propose. Take a scanner with 10.7 MHz IF output and tune it to the GPS frequency. Take the IF output and mix it (say, using a SA602 mixer) with the 1023kHz sequence for an overhead satellite (determined using a satellite tracking program). That sequence can be generated using a crystal oscillator, shift register, and a few gates. Connect a SW receiver to the output of the mixer (tuned to 10.7 MHz) and hear the 50Hz data from the satellite. Maybe even decode it using a sound card. I have the equipment necessary to try this. I'm curious as to whether anyone else has tried something similar, as well as your thoughts on whether this is likely to work or not.
Thanks,
Frank
Old 07-11-2008, 06:56 PM
trixwagen's Avatar
Yeah... I think Geordi tried that same trick in Star Trek to disable the Borg navigation system..
"It's all fun and games until someone closes the thread"
Old 07-11-2008, 06:58 PM
KC0QNB's Avatar
Send a message via AIM to KC0QNB Send a message via Yahoo to KC0QNB
WHY?,. just buy a gps receiver and be done with it, you can then do all kind of cool things with your computer/gps combo
ICOM IC-2200H, IC-2100H, 2x Bearcat III, old PRO-46, hasn't failed me yet.
I am not affiliated with any of the companies, whose links I provide, on this or any other forum.
Grid Square DN90WW
Old 07-11-2008, 08:07 PM
jon_k's Avatar
Why?
For electronic experimentation and the reward of building something and making it work.
Sounds like a fun project. I don't know enough to do it myself, but if I did, I'd be all over it.
I just know enough to use a 555 timer circuit, pots, and a relay to make a delayed off-timer.
N5IPT ๏̯͡๏﴿
Scanning:
Uniden BC246T (Diamond RH77CA) / Vehicle use: Austin Spectra
Amateur: Handheld: Yaesu VX-7R (Diamond SRH77CA); Vehicle: ICOM 2820 (Comet SBB7 2m/70cm)
Old 07-12-2008, 02:15 AM
Do you have a scanner that can pick up –160dBw signals?
Old 07-12-2008, 07:59 AM
Thanks for the reply. I have an Icom PCR-1500 which has a sensitivity of 5uV at that frequency. That would be -93dBm. I have a preamp with 22dB gain specified at this frequency. That would give me -125Bbm, or -155dbW. I have a homemade helical antenna that is supposed to have a 10dBi gain. However, I suspect the actual gain is going to be less due to the homemade construction. If it is 5dBi, that would put me right at receiving -160dbW. But yes, I agree it would be very close. Maybe I could use an active GPS antenna instead.
Frank
Old 07-12-2008, 10:48 PM
More like -115dBm.
Your preamp can't amplify what it can't hear and I doubt it would hear a GPS signal.
I'd go with an amplified GPS antenna. 28 dB gain seems to be typical for a good one. It still isn't enough to drive your deaf receiver. I guess you could try sticking your preamp between them, but it sounds sketchy.
Old 07-13-2008, 07:24 PM
frankh's Avatar
Location: Windsor, Ontario..... on the edge of Sanity, 9 miles south of 8 mile
If you take a look at this it's probably do able, but you may need some more gear. Good luck, and here's the link http://www.rfspace.com/Gallery.html#11
Old 07-13-2008, 10:37 PM
Thanks. 3 foot dish! That's going to be a bit difficult for me. Especially given that the dish will have a fairly narrow focus, and GPS satellites (unlike geosynchronous) are constantly moving. But maybe I can use an active GPS antenna instead.
Frank
Old 07-14-2008, 01:26 AM
Default GPS receiver.
Hello.
Buy one of the really old GPS radios, an early sony marine model will work.
This is a radio with an active antenna and preselector inside a radome with an IF around 45 MHz.
At that point it is run into another IF and detected, a single board.
The rest is also single circuits, only in the computation section are the custom IC.
Very simple by todays standards.
Similar Threads
996 with Internal GPS scannsw Uniden Scanners 13 05-25-2009 11:44 PM
Icom PCR-1500 Sensitivity and NOAA Satellites KG9NZ Space and Satellite Monitoring Forum 1 06-17-2008 10:33 AM
Another 996 GPS question Gmoz Uniden Scanners 5 08-06-2007 11:35 PM
996 GPS lockout use Kirk Uniden Scanners 5 10-07-2006 11:21 AM
GPS and 996 jpjohn Uniden Scanners 1 08-10-2006 03:40 PM
