| Space and Satellite Monitoring Forum Forum for the discussion of the Space Shuttle, Satellites, Military Satcom, and Amateur Radio Satcom communications. |
11-11-2008, 07:16 PM
Sts-126 Endeavour Launch Fri Nite !!
STS-126 ENDEAVOUR launch scheduled this friday November 14 at 7:55pm EST (0055z Nov 15).....
this launch window is PERFECT for a really spectacular view all up the east coast !
hopefully rain won't be a problem in your specific location--looks like it will be here along the NC coast :-(
but there's still the radio comms from Endeavour on 259.7 Mhz AM to look forward to !
so, listen up and look up !!!
God Speed Endeavour....
Barefootdipole
" IN GOD WE TRUST--- ALL OTHERS WE MONITOR !!!! "
11-12-2008, 10:37 AM
Will this be viewable in northern virginia???
11-12-2008, 02:11 PM
Your weather will probably interfere... Keep an eye on http://nasaspaceflight.com
11-12-2008, 03:29 PM
What type of foot print will the comms have... ? are they relitively high powered?
11-12-2008, 04:33 PM
Not high at all, if you aren't fairly close to the East Coast you have no need to try.
11-12-2008, 07:34 PM
I am not familiar with space shuttle communications channels, even though I reside in Florida. It never really dawned on me to try to listen in on any communications, thought I was too far away from the launch pad. I was never sure that I could ever pick them up. They launch from the space coast area, and Im up in Ocala approx 2 1/2 to 3 hours away...
I am excited and awaiting the launch. Is 259.7 Mhz on am the only frequency that they use, might there be an alternative to set the reciever on scan... maybe we can bounce scan 2 frequencies during lift-off and catch some cool comms. Thanks
KEVIN HOELLDOBLER
PRO-106 DIGITAL / PSRedit500 SOFTWARE
UBC3300XLT / BUTEL SOFTWARE
PRO-2006 WELL MODIFIED
PRO-2038
PRO-89
and a few MOTOROLA 2 way radios
11-12-2008, 07:51 PM
That's all you will hear coming from the shuttle on launch / landing.
11-12-2008, 08:37 PM
Does anyone know if this will be carried on the net?
11-12-2008, 09:29 PM
Always live on the net or satellite... http://www.nasa.gov/ntv
11-13-2008, 07:40 PM
Do we have a database section for shuttle and iss frequencies to import? Living in Colorado can I monitor any communications from the shuttle or the ISS? Thanks.
11-13-2008, 10:05 PM
There's nothing you can hear in Colorado. Just the 259MHz frequency on launch and landing.
11-13-2008, 11:49 PM
anyone copy any UHF milsat test comms yet?
Listening To The Skies:
Watkins Johnson 8617-B
Watkins Johnson 9518BE
Racal RA6790/GM
Racal RA2309B
AN/URC-110
BC895XLT
Pro-2042
Pro-2045x4
BC898T
www.Signal-Intelligence.com
11-14-2008, 04:32 AM
So what freqs should I be listening to if I'll be at the launch with a RS pro-95?
11-14-2008, 06:00 AM
Wiki Admin
Since the PRO95 doesn't cover the UHF milair band, and we don't know where you are, your best bet is likely to be the various ham repeaters that, at times, relay mission audio. Not many are doing that here in Maryland anymore. I think there is a list on the Grove PDF file (link below), but it's likely a bit dated.
http://www.monitoringtimes.com/html/...unications.pdf
73 Mike
11-14-2008, 11:41 AM
Thanks, and I meant I'd be at the launch as in watching it in Titusville.
11-14-2008, 12:33 PM
"Do we have a database section for shuttle and iss frequencies to import? Living in Colorado can I monitor any communications from the shuttle or the ISS? Thanks."
You can track the ISS and listen to it as it passes over your location.
11-14-2008, 06:15 PM
Any freqs I can get for here in South East PA? I have the one in that link that was posted here.
11-14-2008, 06:19 PM
261.575 FM mode up with Launch related satcom
5.711- SRB recovery ships up
259.7-Shuttle direct comms after launch
10.780-Cape radio launch related comms
Racal RA6790/GM
Racal RA2309B
AN/URC-110
BC895XLT
Pro-2042
Pro-2045x4
BC898T
11-14-2008, 06:21 PM
Thanks.
11-14-2008, 06:49 PM
Not personally, but this was posted on rec.radio.scanner:
11/12/08
Today, there were various comms heard to prepare the launching of the
Space Shuttle STS-126 on 261.5750 MHZ FM mode by Sat.
KA3FYU
