Go Back   The RadioReference.com Forums > Topic Specific Forums > Space and Satellite Monitoring Forum
Space and Satellite Monitoring Forum Forum for the discussion of the Space Shuttle, Satellites, Military Satcom, and Amateur Radio Satcom communications.
Old 11-06-2011, 09:43 AM
The_dog's Avatar
Smile ? Satellite scanner BC142XL Help
Need help id-ing a scanner and equipment
the scanner is a BC142XL and on the display it has a label
(Modified for Satellites By SSC)
with this scanner it has a
Software Systems Consulting
WEFAX DEMODULATROR
WEFAX DEMODULATROR is this some sort of data slicer 2-level 4-level or somthing else
what type of software does the WEFAX DEMODULATROR need
and what type of antenna do i need a polarized or ground-plan
and what is a radio like this worth Price wise
i am use etrunker.exe and a 2-Level Data Slicer to Decode Trunked Radio Systems
i am looking for more info on the listed equipment
Old 11-06-2011, 10:03 AM
Default Price wise,
some where around the 30 dollar range.
BC142XL | eBay
Concerning the rest of your inquiry, I've no info.
Freedom, a beautiful way of life. Roger
Old scanners like me:
Old 11-06-2011, 10:19 AM
OCO's Avatar
OCO OCO is offline
Google " SSC wefax demodulator " , There's a whole page of hits, including a vintage PDF catalog from SSC and their webpage (circa 2005)..
"An opinion should be the result of thought, not a substitute for it." - Jef Mallett
. Heathkit CR-1
Old 11-06-2011, 11:06 AM
Wiki Admin Emeritus
Moved from the HF digital decoding forum since it has nothing to do with freqs below 30 Mhz
Old 11-08-2011, 03:22 PM
RohnsRadio's Avatar
not sure what you are asking. but the radio i think you talking about was a modified version. it was modified to receive wideband. it is not the off the shelf verson of the radio.
hope that answers the question
as far as an antenna goes. you will have to track the bird on the pass. you can use a antenna like a ground plane but will not be real happy with the pictures you will get.
Rohn Daughtry, BSW
kd4hct
probation 216
USCGAUX
