Ok guys I'm joining the Electroline club, just ordered the EDA2800. Giving this a try, seemed affordable and the port isolation numbers are higher than my current splitter. Gonna feed it with my DPD/LP 9913 coax 80ft, into PAR FM and PAR 162VHFSYM. I'm hoping the +4db isn't too much for the scanners. I will post results next week and welcome comments and opinions. The actual math is this (+8db for the dpd/lp, -4db for thecoax, ?? for the PAR filters, and some minor - for adaptors, then the EDA2800 +4db) I saw that modified EDA with BNC connectors, don't think I need to go that far with this setup. OBTW the current splitter is a Streren 201-234 from Fry's. Not bad, (-9db) but I still get scanner to scanner problems, the port isolation is only 20db so maybe the EDA2800 with 25db will be just enough to overcome that problem.
