Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Splitters, Filters and Multicouplers
Splitters, Filters and Multicouplers - For discussion of all inline devices used to split, combine or amplify a receive signal. This forum is not for any bi-directional (transmit) device. Use the Amateur or Commercial Radio forums for those.
Old 11-11-2016, 3:00 PM
sibbley's Avatar
Default MCA204M Multicoupler
Has anyone ever run one of these STRIDSBERG units while mobile? I am wondering if there is a cigarette lighter adapter power supply.
Too many scanners and radios to use at one time, But I'm trying!
Old 11-11-2016, 3:12 PM
mass-man's Avatar
Hmmm....interesting idea! I would wonder about it picking up vehicle generated noise/hash! It is designed for 12vdc so a cig lighter power supply SHOULD work....I would worry about that moment you start your vehicle and the voltage is often above 14vdc, whether it would handle it.
I think a call to the folks in Shreveport might be in order....but very interested in hearing what they have to say...
Cleve/W5CEM
Old 11-11-2016, 3:45 PM
buddrousa's Avatar
I have seen postings before where they have been used. Use the correct DC plug fused and the correct polarity
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 11-11-2016, 4:51 PM
sibbley's Avatar
The thing that worries me is the AC adapter is 12 volt, but only 200mA. I guess I'll shoot Stridsberg an email and ask what they would recommend. The multicoupler works great, I thought it would be a great addition while mobile.
Old 11-11-2016, 5:04 PM
I always make my own 12 volt adapters for all my mobile equipment if it doesn't come with one. I put a fuse that is slightly higher that what the equipment uses to operate. I did the same to my multi coupler since it is 12 volt. Never had a problem. I don't plug mine in until I crank the vehicle just to be safe.
Old 11-11-2016, 5:30 PM
My Multi Coupler is also the MCA204M. I always check the power usage of the item and match the fuse with that. If you are only using scanners with that then you can hook the Coupler and scanners via a accessory combo adapter without going over the accessory maximum which is 10 amps on most cars. The real Cigarette lighter outlets were 15 amps. My mobile ham radio's use 8.5 amps so I can only hook one each to each outlet and I use a separate antenna for each radio (2 ham radios) so I don't have to use a duplexer. I actually bought my male accessory ends at radio shack down here. Some are still privately owned and still have good stuff but you can get on internet.
Old 11-11-2016, 5:53 PM
sibbley's Avatar
I've got 3 accessory outlets. I would use the rear console outlet for the multicoupler, so that would be on it's own. I've got a Trailblazer, so not much usable real estate for mobile scanners. On days when I'm running around searching for new radio traffic, I use my hand helds and HP2. I was out running today and thought it would be nice to try the multicoupler with a single antenna.
Thanks, I'll keep looking into making this work. With the cost of the multicoupler, I want to make sure I do this right and not burn the thing up.
Old 11-11-2016, 7:15 PM
cg cg is offline
I have had one in my current vehicle for 6 years now. I use the cigarette lighter to power the multicoupler and 3 Uniden 996XT scanners. The 4th port is for my 396 or my SDR setup with another 4 port unit, 4 SDRs, and a 12VDC USB hub. Never a power issue.
chris
Old 11-11-2016, 7:52 PM
buddrousa's Avatar
That sounds like a nice set up.
Old 11-11-2016, 8:33 PM
Sounds like a nice setup cg. I would need a chauffer if I had that much in my vehicle so I could play with my radios.
Old 11-12-2016, 7:12 AM
sibbley's Avatar
chris
Holy cow, 3 996's, what kind of car do you drive? Did you make your own power cord for the multicoupler?
Old 11-12-2016, 7:30 AM
cg cg is offline
A Uniden power cord will work. The Stridsbergs used to be different but changed quite a while ago to the 5.5mm, 2.1mm plug/jack like the unidens.
chris
Old 11-15-2016, 5:58 AM
sibbley's Avatar
chris
Thanks to all. I did get confirmation yesterday that the Uniden power cord will work. Now I'll get setup for my Friday ride around and try this out.
Old 02-20-2017, 7:59 PM
Did you ever end up getting this installed in a vehicle? Any noise issues related to vehicle power?
(12)CDM1550s (3)XPR4550s (5)XTS2500s (2)XTL2500s (2)EX560s BCD436HP BCD536HP IC-A110 VXA-220 And a whole lot more.....
Old 02-21-2017, 5:35 AM
sibbley's Avatar
I went with a passive multicoupler from Stridsberg, the MC202. No power needed. It works pretty well on a short run such as in the car. No noise issues. Not as good as the active unit (with power), but good enough.
My decision to go with the passive unit was influenced by not wanting to constantly reach back and pull the power plug since my power supply is constant.
Old 02-24-2017, 11:39 PM
trp2525's Avatar
While Stridsberg has an excellent reputation for producing quality products, I believe the MC202 2-port passive multicoupler (Receiver Multicouplers, Passive and Active, HF to VHF/UHF) is highly priced ($75) for what it does. The specs show it to have a 3.5 dB loss at each of the 2 output ports (fairly standard for a 2-way passive splitter) with port-to-port isolation of 25 dB. All 3 connectors on the multicoupler are BNC female (with an option for TNC connectors instead) and the operating frequency range is 10 to 1000 MHz.
You could accomplish the same thing by using a high-quality TV splitter such as the Channel Master CM-3212 2-way splitter (2 Way Digital Splitter (CM3212) | Channel Master) for $6. The specs show the loss to be 3.5 dB at each of the 2 output ports with a 35 dB isolation between outputs. All 3 connectors are F female connectors and the operating frequency range is 5-1002 MHz.
If you decide to use the Channel Master splitter (or equivalent) but want BNC female connector ports instead, you could use F male to BNC female adapters (https://www.firefold.com/bnc-connect...le-f-type-coax) at each port for $0.89 each and then have the same connectors as the Stridsberg MC202 unit. The total price for the splitter and 3 adapters would be less than $10 compared to $75 for the MC202. Of course technically you would be better off terminating your 3 coax ends in F male connectors to avoid the use of adapters but the choice is yours.
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, TRX-2, BC950XLT, BCD996XT, BCD396XT, SDS100, Motorola Minitor II, Antenna Specialists MON731
