Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Splitters, Filters and Multicouplers
Splitters, Filters and Multicouplers - For discussion of all inline devices used to split, combine or amplify a receive signal. This forum is not for any bi-directional (transmit) device. Use the Amateur or Commercial Radio forums for those.
Old 02-15-2017, 5:12 PM
KD6HRI's Avatar
Default Home brewed multicoupler
Does anyone know if there are any schematics or kits out there to make your own multicoupler to feed multiple scanners off one antenna. I would like to get a Stridesberg, but at $185 off their site is alot to invest. It may come down to "biting the bullet" and buying one, but I wanted to check with you all and see if there are more cost effective options out there.
Radio Shack PRO-197 / Uniden BCD536HP / Uniden BCT15X / Whistler TRX-2 / Whistler WS-1088 / Yaesu FT-8900R / Yaesu FT-7900 / Yaesu FT-60R / TYT-9000D 220mHz
Old 02-15-2017, 5:40 PM
737mech's Avatar
Default 8 port splitter
Are you wanting to get all of your radios connected? Maybe just 8? Here's what you should try Electroline EDA-2800 there's always one on ebay. Many people with many scanners use them and they work. If you decide to go Stridsberg later you will at least already know how good your antenna is and the money spent for the EDA will be nothing by comparison to the investment of MCA multicoupler. Just suggesting go cheap first. Then later when you have extra money buy the MCA from Stridsberg.
Old 02-15-2017, 6:12 PM
majoco's Avatar
Here's a good article from John Bryant. You may have to find out about the core material for VHF but another option is to use the binocular core from a TV antenna 300 to 75ohm balun.
DXing.info › Equipment
Old 02-26-2017, 5:19 PM
this again is the huge advantage of using 75 ohm Infrastructure
all you need is a 10 dollar TV preamp and a splitter
or you can just buy a Channel Master CM-3418 8 port distribution amp and be done with it
you can also buy a .5db noise figure amp for under 100 bucks and use
a TV splitter
either way the stridsburg is WAY over priced for only a 2.2db noise figure amp
it has a similar noise figure to the Channel Master so it appears to simply be a 50 ohm version of a TV unit
Old 02-26-2017, 5:40 PM
buddrousa's Avatar
I went from the TV splitter and amp had to deal with noise bought my first Stridsburg did away with the cheap amp and TV splitter and the noise went away and more signals started popping up and buy stridsburgs when they pop up
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
Old 02-26-2017, 7:22 PM
DXing.info ? Equipment
Hell just flip the antenna vertical and use the whole setup!
I think I have it all now, from low to high,Icom R75,BCT15,Pro 18,Pro197, Pro106, 12 foot Unimesh C-band dish, 6 foot Ku band dish. Now if only I had the time to use them all!
Old 02-28-2017, 12:52 PM
majoco's Avatar
What are you talking about?
Old 02-28-2017, 1:37 PM
cmdrwill's Avatar
TV signals are horizontally polarized. Two-way radio signals ore Vertically polarized, that is why you would 'flip' the antenna.
Old 02-28-2017, 1:57 PM
I am using one of these Electroline EDA-2800 but only in the 4 port and it works great. I am using a Diamond Discone antenna.
Ran 50 feet of feed line from the antenna to the Electroline. Then ran a 100 feet from the amp to another 3 port splitter and running 3 radios with no issues. It's not the most best setup but it works great
I am using RG-6 and compression fittings.
Old 03-08-2017, 9:06 PM
I installed a channel master 8 port tv line amp for the county 911 center
ran quadshield rg6 to all 8 receivers
The scanners now actually hear signals better than the their Motorola radios
Old 03-09-2017, 11:19 AM
rbm's Avatar
rbm rbm is offline
This is similar to what I've been using on six different antennas for a lot of years.
That photo is of the setup I use when I go to the homes of friends so they can see how much difference it will make at their location.
The amp is a Holland LA-520, 50-2050 MHz. 20 dB gain. (around $12-$16 on ebay)
Spec Sheet is here: https://www.perfect-10.tv/webstore/s...ets/LA-520.pdf
Using a DC block as shown, you can mount the amp. directly at the antenna.
My permanent installations at home use (mostly) RF Bay, Inc. LNA-1000 pre-amps instead of the Holland shown in the photo.
They're much better, and much more expensive.
One of my antennas is feeding 32 scanners simultaneously including my two feeds on Broadcastify.
Rich
