Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Splitters, Filters and Multicouplers
Splitters, Filters and Multicouplers - For discussion of all inline devices used to split, combine or amplify a receive signal. This forum is not for any bi-directional (transmit) device. Use the Amateur or Commercial Radio forums for those.
Old 07-07-2017, 12:52 PM
dave3825's Avatar
Default Lna4all vs catv amp
Has anyone seen any review of one vs the other? Thinking of getting one but don't want to find it will give the same results of the tv amp I am using. Antronix MRA1-15. I don't fully understand what all the specs mean exactly.
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
Old 07-07-2017, 12:54 PM
mule1075's Avatar
Link?
Sent from my SM-S907VL using Tapatalk
Uniden BCD536HP/436HP/796D/250D Motorola HT1000/GM360
Old 07-07-2017, 1:10 PM
prcguy's Avatar
The only specs in the advertising is a 3dB noise figure, which is not very good compared to preamps made for communications use. Everything else in the advertisement are industry buzz words that mean nothing.
Bottom line is this amp is designed for use in a closed cable TV system and not necessarily for connecting to an antenna. A CATV system has a finite number of carriers, all at a fairly low level compared to off air signals. If you live in an area with lots of strong radio signals, paging systems, cell phone towers, etc, amps like this can easily overload and cause more problems than your trying to fix.
prcguy
Old 07-07-2017, 11:19 PM
RFI-EMI-GUY's Avatar
Cable amps are going to be optimized for lowest intermodulation distortion, the noise figure, which the ability to hear very weak signals will be a lower consideration in a cable TV system.. Also in a cable TV system, all of the signals are at the same relative level which controls intermodulation effects. However, when you monitor off the air the strong signals from paging transmitters, NOAA weather , FM and TV broadcast, will overwhelm a wideband amplifier and the preamplifier of your scanner receiver. Intermodulation will ensue.
If I were trying to receive satellite signals or moon bounce I would want 0.5 dB noise figure or less, and I would have a filter to prevent out of band signals from reaching the preamplifier.
"Have Spectrum Analyzer, - Will travel" "Going Green"
Old 07-13-2017, 11:50 AM
This is what you want to do, forget about CATV amps unless they are for distribution AFTER the first state LNA and you must make sure that the signal hitting the CATV Amp is not too high otherwise you will have compression and intermods.
https://forums.radioreference.com/sp...-rx-items.html
