Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Splitters, Filters and Multicouplers
Splitters, Filters and Multicouplers - For discussion of all inline devices used to split, combine or amplify a receive signal. This forum is not for any bi-directional (transmit) device. Use the Amateur or Commercial Radio forums for those.
Old 07-02-2018, 1:37 PM
llwade's Avatar
Default MCA204M multicoupler
multicoupler has worked GREAT for the last two years. for past two weeks 4 scanners became very quiet. I put portable antenna on all 4 scanners and they began talking again. Suspecting the antenna , I bypassed multicoupler and went from antenna direct to one of the scanners. a lot of traffic with direct connect to the scanner. Paid $200.00 for the multicoupler. Is there any sure way to check the multicoupler. If it is bad, is there somewhere it can be sent for repair. thank you for your time
73s
LLWade
email: leroywade@mediacombb.net
BCD996XT, HP-1, BCD536HP, SDS100
Old 07-02-2018, 2:05 PM
prcguy's Avatar
You already figured it out. Antenna to multicoupler to four scanners - quiet, no signals. Antenna direct to scanner, no multicoupler - lots of traffic.
The only differences are the multicoupler and an extra cable per scanner are in line meaning one of them is bad and you probably don't have four separate cables that failed at the same time so that leaves the multicoupler. There is also the power supply that powers the multicoupler and I would check that right away. If its bad, replace it. If its good then the amplifier in your multicoupler took a dump and it would usually be returned to the factory for repair.
Old 07-02-2018, 2:06 PM
cg cg is online now
Receiver Multicouplers, HF VHF/UHF.
chris
Old 07-03-2018, 12:38 PM
N9JIG's Avatar
Sheriff
Stridberg stands behind their products. If the power supply is good like PCRGUY advised then send it to Strids for repairs. If it is within warranty he will repair it and send it back, out of warranty there may be a charge.
Typically what happens is that the protection diode pops due to static, two-way transmissions in the area or perhaps a nearby lightening strike. Once replaced it would work as new again.
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
Old 07-05-2018, 3:25 AM
llwade's Avatar
THANK YOU ! for the response. if only the problem was constant then it would be real easy to figure out what was going on. I will make the contact and send it back. going from 4 scanners to 1 is real frusatrating.
73s
LLWade
