2017 NASCAR Frequencies
jeepsandradios
East of the Mississippi
Here is my list from Bristol. There were a few changes from last year. I'll be in Charlotte next month and will verify some CTCSS/DPL codes that are missing.
Monster Cup
Frequency Alpha Tag PL/DPL
466.6875 JAMIE McMURRAY 226
466.2125 BRAD KESLOWSKI 125
469.0125 AUSTIN DILLON 131
461.3125 KEVIN HARVICK 186.2
468.2125 KASEY KAHNE 218.1
466.275 TREVOR BAYNE 43
461.6625 JJ YELEY 365
466.9625 DANICA PATRICK 205
462.475 DENNY HAMLIN
469.375 TY DILLON
464.6375 CLINT BOWYER
461.25 REED SORSON
460.95 RICKY STENHOUSE 85.4
467.45 KYLE BUSCH 734
469.5375 DANIEL SUAREZ 155
462.525 MATT KENSETH 265
465.8875 RYAN BLANEY Search
465.8875 JOEY LOGANO Search
452.0875 GREY GAULDING 455
467.0625 CHASE ELLIOT 229.1
461.5125 PAUL MENARD 412
468.575 RYAN NEWMAN 311
467.25 MATT DIBENEDETO 94.8
456.5875 JEFFREY EARNHART Search
467.1125 LANDON CASSE L 624
460.275 CHRIS BEUSHER Search
463.3125 LDAVID REGAN 703
469.1375 KURT BUSCH 74
452.475 KYLE LARSON 546
463.3375 ARIC ALMIROLA 243
463.6875 AJ ALLMENDINGER 162
465.8625 JIMMIE JOHNSON 91.5
451.7125 TIMMY HILL
461.275 DERIK COPE 503
463.2125 COLE WHITT
451.325 BRENDON GAUGHN
467.275 ERIC JONES
461.2625 MARTIN TRUEX JR
458.1125 COREY LAJOIE 54
466.7875 DALE EARNHARDT
469.5875 MICHAEL McDOWELL 134
469.5625 DJ KENNINGTON
461.2 NASCAR 1 432
464.6 NASCAR 2 631
bstane001
nascar raceview
i use nascar raceview mobile app. i was curious if what drivers said on that app is exactly what the frequencies are transmitting. or is the app filtered to make it sound like your hearing everything.
PiccoIntegra
North Texas
For the most part, yes it's what you'd hear on the scanner at the track. They do try and censor the cussing quite a bit, which is irritating. Since my TV is usually ahead of the scanner audio, I can sync the two. Whenever they "scramble" the cussing, it throws the sync out of whack. :roll:
padiddle35
Hi kb2ztx. Thanks a ton for posting this list it's a huge help for us this week at Dover. I'm wondering if you picked up any more cup car tones or codes?
Thanks again
73 KB1AMV
con40mb
New York
Pl tones
How do you get the PL tones? I just looked in my RE3000 for ten mnutes and couldnt figure out how to find them. I just over the air programmed it at Dover yesterday.
Im looking for the Xfinity series PL tones for my other scanner.
padiddle35
I think racing electronics hides the PL tones in the scanner. They can have clear scanners that don't pick up the other chatter on those frequencies and the lay people with personal scanners are stuck listening to the static and digital r2d2 thus forcing us to depend on them and their scanners for the best scanning experience. I do know for a fact that they have all the PL tones at the track side trailers but they refuse to give them out. Bottom line, grab a scanner like a bcd436hp or similar and run the discover function track side during practice and qualifying. Then match the frequencies to a known driver frequency sheet and viola you'll have your ctcss/dcs codes and yes they do use both.
The codes and frequencies above seemed to be accurate at Dover on 6/4/17 so that's a good starting point. If I remember correctly Joey Logano changed his primary frequency but I forget the new one.
Thanks to KB2ZTX for his contribution to this thread. Hopefully I'll be at New Hampshire in July and I'll post my findings then.
con40mb
New York
thats alright, the one scanner will be enough.
If anyone posts the Xfinity series tones ill just program it then.
evilbrad
My head makes a bad antenna
you can find it if you go into the menu but they don't make it easy
jeepsandradios
Here is my scanner dump. I can't upload a csv but this is a txt file. You should be able to open in excel and save as a csv file.
  • bristol-2017.txt
rsrocket1
You don't need PL tones on a receiver, only if you want to lock out interference
If you turn CTSS or PL tones off, you will hear the traffic on the frequency no problem. PL tones are used to squelch out interference and open up the receiver when the CTSS tone (PL tone) is being transmitted, but if you have an old scanner without PL tones or simply turn off PL tones, you'll still hear the chatter.
I've used an ancient Radio Shack Pro 25 in the past at Sonoma and plan to do so again this weekend. It was really entertaining to hear Clint Bowyer flaming (@#&^%!!!) the setup back in 2012 when he first went out onto the track for practice on Friday. Ironically he won the race on Sunday.
