You can now easily listen to shoutcast scanner feeds easily using your iPhone or iPod Touch. To listen to the scanner feeds, once you have the program installed and running touch 'search' and then enter the word scanner.
http://blog.shoutcast.com/2009/01/09...nd-ipod-touch/
IT'S FINALLY HERE...the "official" SHOUTcast Radio App for iPhone and iPod Touch is now available for
FREE at the iTunes App Store.
With the SHOUTcast Radio App, you can:
1. Listen to over 25,000 SHOUTcast Radio stations
2. Save Your Favorites
3. "Shuffle Shake" - Feeling adventurous? Shake your iPhone and iPod Touch to get a random station. You never know what you might get!
You can download the application
HERE
NOTE: If you would like to play high quality station streams (ie. 128k MP3) on your iPhone or iPod Touch through the SHOUTcast Radio App, then you will need to enable high bandwidth streams by going into your Settings. You will only have to do this once.
To enable high quality streams on the SHOUTcast Radio App:
1. Install the SHOUTcast Radio app from the iTunes store
2. Tap on the "Settings" icon from your home screen
3. Flick down to the "SHOUTcast" settings. Tap on the "SHOUTcast" Menu
4. Tap the switch for "Allow hi-bit streams" to ON
5. Exit out of the Settings screen by tapping on your Home button and return to the SHOUTcast App
You should now be able to play high quality SHOUTcast Radio streams over 3G or WiFi.
Edmonton Fire Radio - Broadcasting live audio from the Edmonton Fire Rescue Services, Edmonton EMS & STARS Air Ambulance
EFR IRC server: irc.freenode.net port 6667 Channel #edmontonfireradio
