  #61 (permalink)
Old 06-24-2009, 12:05 PM
mike_s104's Avatar
Originally Posted by kg4pbd View Post
I installed the upgrade to 2.9.2. It ran for about 24 hours without a disconnect from the icecast server. At some point in the last 12 hours it disconnected. I didn't notice it until I got to work and tried to pull up the stream via RR.
The nice thing.....I can restart the icecast stream remotely via Proscan.
One problem...It works as long as I keep Proscan up on the pc where I am located, it doesn't actually restart the stream via the instance of Proscan running at home.
I guess I spoke to soon, it starts the icecast stream however there is no audio on the stream, just the text tags. I guess I can't remotely re-start the icecast stream via Proscan. If I can't resolve this I'm going to have to go back to sending the stream to icecast without Proscan. I hate that because I like being able to control the radio remotely.
enable remote desktop (or VNC) so you can remote in and re-enable or reconfigure remotely.
I also need to add that I've been running 2.9 for a while and it works great. Thanks Bob!
  #62 (permalink)
Old 06-24-2009, 12:43 PM
Hmmm the auto reconnect should have caught the stream going down. I think I had it already happen once here.
  #63 (permalink)
Old 06-24-2009, 03:03 PM
ICP963's Avatar
Send a message via AIM to ICP963
I am also having trouble keeping ProScan alive on my IceCast feeds. Bob will figure it out though, He has done a great job so far.
Roy Schahrer ICP963
e-mail k8x815@cox.net
http://www.incidentcommandpage.com
  #64 (permalink)
Old 06-28-2009, 09:18 AM
How is Proscan checking to see if the feed is still running? Personally I found a php script that I run on my steaming machine that just checks the mountpoint evert x mins so I know how many are online. When the number stops showing I know my feed is offline. I wonder if checking the mountpoint would be a better way.
Anywho, I purchased proscan on Thursday.
  #65 (permalink)
Old 06-29-2009, 09:06 AM
NYRHKY94's Avatar
Default Alpha Tags Thru Web Server/Scan Cast
Hi Bob
I could use some clarification/help on streaming alpha tags via the new Web Server/Scan Cast feature. My "current set-up" is listed below, followed by the clarification/questions I now have:
CURENT CONFIGURATION:
Bedford, Derry, Hudson NH Police
Uniden BCD996T
Simplecast for Stream Encoding
Talk Group Monitor for Tags
Manchester NH Police & Fire
Uniden BC898T
QUESTIONS/CLARIFICATION:
1. Can I now eliminate both Simplecast and Talk Group monitor to stream tags thru the Proscan Web Server/Scan Cast feature?
2. If the answer is yes, are alpha tags only possible with the BCD996T and "NOT" the BC898T? I don't see the BC898T on the supported scanner list, so I'm assuming tags are still not possible eve with the new Web Server/Scan Cast feature.
What I'm trying to do is have the least number of software components running on my streaming PC's, but also continue to provide Alpha Tags where possible. I'm assuming alpha tags are still only possible with just Uniden scanners, not Radio Shack or GRE?
Thanks in advance!
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
  #66 (permalink)
Old 06-29-2009, 11:03 AM
ProScan's Avatar
Originally Posted by NYRHKY94 View Post
Hi Bob
Uniden BCD996T
Uniden BC898T
On the Uniden BCD996T: Yes
Text tags can be retrived from any program that puts the text tags in the title / caption area so if the 898 application puts text tags in the caption area the ProScan can retrieve it.
Click the metadata button and choose the application.
There is a bug with the .net framework library function that ProScan uses to get other application titles and was noticed when getting the title from ID Tracker because ID Tracker was written in vb6 and vb6 uses a hidden main window. The title may not be correct. The bug will be fixed in the next version.
Thanks in advance!
Bob
Taking Computer Aided Scanning to the next level!
http://www.proscan.org ProScan Web Server http://proscan.dyndns.org:443/
bob@proscan.org
  #67 (permalink)
Old 06-29-2009, 11:37 AM
ProScan's Avatar
I will be looking at this next. What kind of indications do you get when you say "having trouble keeping ProScan alive'? Is there a message in the message box indicating that the connection was lost from ProScan to the IceCast server.
Bob
bob@proscan.org
  #68 (permalink)
Old 06-29-2009, 12:36 PM
kg4pbd's Avatar
Hi Bob,
My experience has been Proscan loses connection with the icecast server yet the status light is still lit and Proscan still shows I'm connected. Usually I don't notice this until I get the email telling me the feed is down. It usually seems to be around 12 hours after starting the icecast connection but I can't say for sure.
BTW this is using 2.9.2.
Thanks,
Scott, kg4pbd
  #69 (permalink)
Old 06-30-2009, 01:41 AM
ICP963's Avatar
I have received the RR email that the feed was down and ProScan still thinks it was connected. Though the last 24 hours it has been running with no issues.
Roy Schahrer ICP963
  #70 (permalink)
Old 06-30-2009, 10:39 PM
ProScan's Avatar
I have started to work on the loss connection detection and reconnect.
Email me for the latest file to knock this one down.
Bob
bob@proscan.org
  #71 (permalink)
Old 07-03-2009, 12:59 PM
ProScan's Avatar
Default ProScan 2.9.3 is out.
What's New
* ScanCast - TESTING detection of loss connection and auto reconnect.
* ScanCast - RadioReference auto configuration.
* Remote Scanner Over IP - Audio from version 2.0 back in.
* Special Request - Writes current channel information to a text file option.
I did work to the detection of the loss connection ProScan ScanCast --> IceCast. Let me now how it's working out.
http://www.proscan.org/ProScan_2_9_3.zip
Note that anytime the connection from ProScan ScanCast to the IceCast server is lost and ProScan ScanCast restarts (manual or auto), The media player connected to the IceCast server needs to be restarted.
Bob
bob@proscan.org
  #72 (permalink)
Old 07-04-2009, 02:57 PM
Remote Scanner is working here once again. thanks.
  #73 (permalink)
Old 07-05-2009, 05:37 PM
kg4pbd's Avatar
I've been running 2.9.3 for over 24 hours and no disconnect issues. It looks like you fixed it! Thanks.
Scott, kg4pbd
  #74 (permalink)
Old 07-05-2009, 06:10 PM
MY Isp has a UPS fire at there central Data centre last night and Proscan reconnected without issues.
  #75 (permalink)
Old 07-05-2009, 11:26 PM
ProScan's Avatar
Thanks for the reports.
The disconnect detection is very simple as I have it now. Anytime there is an error when sending the audio out, ScanCast will disconnect and will attempt to connect in 10 seconds if the auto Reconnect is on.
Time will tell if anymore work needs to be done.
Bob
bob@proscan.org
Similar Threads
ProScan Web Server and ScanCast Annoucement ProScan Streaming / Broadcasting / Audio Recording 0 05-13-2009 05:58 PM
