| Streaming / Broadcasting / Audio Recording Interested in putting your scanner online for others to hear? Want to listen to other radios on the internet. This forum is here for you to discuss these topics related to streaming scanners online. |
06-30-2009, 12:55 PM
The "audio only (no tags)" and "stereo feed" options will be released later this week.
Check here, or on my web site, for the notification.
Peter
OSR
06-30-2009, 06:16 PM
Scanners without tag support
Originally Posted by scannerkid
So will people with scanners that do not support tagging, be able to use this program with ease. As an "Audio Only" options or whatnot? And does it work well with scanners that do not have tag support?
I've been using one of the first versions of ScanCast on a BC895XLT feeding just the audio and it works great. It's providing audio to my feed here on RR and the flash player on my web site and has worked with no problems running on a P3 with Win98 and newer systems using XP. And setting it up was easy as well. Give it a try.
"Life is what happens while you are making other plans" - Lennon
______________________________________
Pro 33, Pro 41, Pro 2020, BC895XLT, Pro 197
07-01-2009, 10:14 AM
I agree with George. I've been running an audio only feed with a Radio Shack Pro-2096 since the first version of ScannerCast came out. No issue at all. I am however glad to see Peter making it standard functionality that is apparent to all users.
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
07-01-2009, 10:47 PM
NEW VERSION: V0.8 (701) -- Adds Audio-Only and Stereo Support
Finally!
V0.8 (701) of ScannerCast has been released. This version adds, by popular demand:
1) Audio-only support -- Lets you use ScannerCast with just about any scanner to create a feed that does not have alpha numeric tags associated with it.
2) Stereo feed support -- Lets you send two feeds simultaneously: One on the LEFT audio channel another on the RIGHT audio channel. ONLY ONE FEED CAN HAVE TAGS.
Both of these features were widely requested by users... so here they are!
Click to go to K1PGV's ScannerCast page
Enjoy... and, as always, I'm eager for your feedback. Send me email at my callsign (k1pgv) @arrl.net.
Peter
K1PGV
07-01-2009, 11:31 PM
I have winamp but I can not figure out how to play my feed through winamp to see if it is working. Any help please?
07-02-2009, 09:46 AM
Are you sending your feed through RR or do you just want to listen to it locally??
If you just want to TRY it to see if it's working, you can start Winamp on the same system as ScannerCast and point it to the URL The RadioReference.com Forums - Powered by vBulletin (assuming you used "5700" as the ScannerCast port).
Peter
K1PGV
07-02-2009, 11:21 PM
Error
I tried downloading scannercast, but i keep getting an error message. The "unzipping" part goes well, but when i double click to run the application I get the error:
"The application failed to initialize properly (0xc0000135)."
Any suggestions on what might have caused this?
Daniel
07-03-2009, 12:03 AM
OH/WV DB Admin
Daniel
It is likely that you do not have Microsoft .NET installed.
Or follow the directions on Peter's webpage - About the .NET Framework.
07-03-2009, 12:16 AM
Alright, I'll try that.
Daniel
07-07-2009, 09:54 PM
Downloaded the program and had it up and running within 3 minutes. One of the best and easiest programs to use without a doubt! A+++++++
Thanks Alot!!
Daniel
07-30-2009, 06:40 PM
Thought I would post to see if Peter's working on anything new for ScannerCast. This thread has been rather...dead. I really think the thread should be stickied!
--Patrick
Providing Feeds for:
Putnam, Hancock, and Lawrence, OH
Cabell and Wayne,WV
Boyd,KY.
07-31-2009, 11:04 AM
Hi Patrick,
Thanks for asking!
As well as being busy with "family things", I've been trying to let the current version of ScannerCast get a lot of use to shake-out any bugs or problem scenarios with the core functionality. So far, it seems to be pretty stable across a very wide variety of operating systems and computers, and there don't seem to be any key features missing. For example, support for stereo feeds and audio-only feeds were the direct result of user feedback.
There are still some pretty exciting features planned for release before V1.0 is complete. These are:
1) Support for remote scanner control via the web -- no client software needed (obviously, this doesn't apply to scanners being used in "audio-only" mode); This will let you connect to your scanner via an internet browser to change settings (lock-out channels, change scan groups, etc).
2) Support for saving/restoring configuration parameters from named files. Right now, you can run multiple copies of ScannerCast on one machine, but it only saves the settings from the last copy you run. This makes it difficult for folks who support multiple feeds from one system (you want to set all the copies of ScannerCast that you have running to automatically restart if the system is rebooted... right now, that doesn't work well).
3) Implementation of a "VU meter" that will help you set the volume of your feed accurately. This is a surprisingly difficult thing to do, and it takes a ridiculously large amount of CPU time to display. So, while this is one of Gordon's original suggestions for the program (which I have definitely NOT been ignoring) I can't guarantee that it will make V1.0 -- If I *do* provide this feature, it'll almost certainly be in a separate pop-up dialog (so it won't be something that's ordinarily displayed).
4) A "check for updates" check box, that'll enable ScannerCast to automagically check K1PGV.COM to see if a new version is available.
5) More complete documentation. This is, basically, a never-ending quest.
6) Anything else I hear from users that they say is really desireable.
So... that's the plan. My goal is to have V1.0 complete (out of beta, done, stable) by the end of the summer.
In case you're curious, there have now been several hundered downloads of ScannerCast.
Again, thanks for asking. And, thanks to EVERYONE who's sent me feedback/comments/ideas for ScannerCast. If we all work together, we'll make ScannerCast the best possible scanner streaming application.
Peter
K1PGV
07-31-2009, 06:45 PM
Thanks for the update. Yes this version is very stable I've had no issues at all with it. I look forward to testing future betas prior to V1.0. Thanks for your time, it's appreciated!
--Patrick
Cabell and Wayne,WV
Boyd,KY.
08-05-2009, 08:55 AM
Out of curiosity, will this software allow us to send a single feed to multiple servers like oddcast? We currently use two servers, one on the east coast and one on the west. If one server goes down our listeners can easily switch to the other server to continue listening.
Edmonton Fire Radio - Broadcasting live audio from the Edmonton Fire Rescue Services
EFR IRC server: irc.freenode.net port 6667 Channel #edmontonfireradio
08-05-2009, 09:38 AM
<QUOTE>
</QUOTE>
Thanks for asking. Unfortunately, the answer is "no" -- This isn't supported, and this feature is not planned.
Peter
K1PGV
08-06-2009, 10:55 AM
Peter are there any plans so support the bc 246t scanner for text tag streaming??
73
Tim
kg4jjs
08-06-2009, 11:01 AM
Hi Tim,
Thanks for asking. The answer is "Yes", more scanners (including the 246t, which has been requested many times) will be supported in V2.0 -- Unfortunately, I still have V1.0 to finish :-)
But definitely, support for tags with more scanners is coming,
Peter
K1PGV
08-06-2009, 11:28 AM
Remote control via the web, this is going to be excellent!
08-06-2009, 12:15 PM
I just tried the new version, looking good!
Lots of radios, not enough antennas...
08-06-2009, 12:56 PM
A couple of comments:
It would be really nice if it would "remember" which sound card when I start it up.
It only seems to send tags from my PSR600 when scanning, not when in favorites.
