mitbr
Ok if your like me and run your broadcast from a second computer that only runs your broadcast its very easy to set this up automatically....
Step 1 make sure your oddcast has a check mark in the box auto connect
Step 2 right mouse click on your start menu button on the task bar and select explore all users
Step 3 open the programs folder then open the startup folder
Step 4 place a shortcut to your broadcaster into this folder by right clicking on the program shortcut on your desktop and copying into the startup folder
That's it your done... now when you start your computer your broadcast will start running the only this you have to do is turn your scanner on,
This should work on all versions of Windows.
Mods if you feel this is worthy of a sticky you have my permission!
Tim
73's
kg4jjs
Clearwater Fl pd feed provider
Tim
73's
kg4jjs
