Old 07-20-2009, 03:25 PM
Default very loud hum in backround
hi im setting up live feeds and im having a little problem and would appreciate any help if you could listen to my feed there is a very loud hum in the background and i don't know how to fix it thanks a ton
Old 07-21-2009, 11:09 AM
ScanPEI's Avatar
Hums in the audio can be caused by many different things. It could be, for example, your antenna, audio cable, interference, ect. However, there are ways to fix or reduce this hum. You can get a Ground Loop Isolator, available at Radio Shack for $16.99, and this might solve the problem. I also have a hum in my audio, but only when it rains and its caused by my outdoor antenna. However, the hum is not loud enough to really affect the audio and is really only detectable during silence. Hope This Helps!
Daniel Deziel
President - ScanPEI
Old 07-21-2009, 11:17 AM
N_Jay's Avatar
Hum only when it rains says you have a ground problem.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 07-21-2009, 11:18 AM
Smile
THANKS EVERY ONE FOR THERE SUGGESTIONS it looks like i found and fixed the problem it was the outlet that computer was plugged into it didn't have a good ground so i just plunged my computer into a different outlet and now its crystal clear.
Old 07-21-2009, 11:26 AM
N_Jay's Avatar
The trick to finding ground loos is to temporarily break and add grounds looking for changes.
The areas to be concern are any cable where the ground is connected at both ends, such as audio cables, antenna cables, and data cables, and cables connected between devices that have their own ground points, such as power supplies.
Additionally, sometimes the hum is not a ground loop, and is just power supply hum or digital noise from one of the components.
Old 07-21-2009, 11:36 AM
ScanPEI's Avatar
So, the best way for me to get rid of that, is to ground it. Its a fairly old antenna, so I thought it should have been already grounded. But I'll check that out!
Daniel Deziel
President - ScanPEI
Old 07-21-2009, 11:45 AM
N_Jay's Avatar
The best way is to find the problem and fix it.
My guess is you have very little ground when it's dry and the water is "fixing" the ground, and showing up a ground loop.
Old 07-21-2009, 04:49 PM
Use a 1:1 transformer on the audio input to the computer to isolate and prevent ground loops. problem solved.
Old 07-21-2009, 04:52 PM
N_Jay's Avatar
That is what a ground loop isolator does, and it might or might not work depending on the specific problem.
Similar Threads
Help with hum please: Ground Loop Isolator stop hum yoopernewsman Michigan Radio Discussion Forum 24 07-21-2009 09:30 PM
Hum from Pro 163? pkivolowitz Radio Shack Scanners 12 06-14-2009 11:19 AM
Loud Boom Rocks Southern Kentucky ShawnCowden Kentucky Radio Discussion Forum 0 02-14-2009 01:17 AM
Hum from scantenna bomber2782 Antennas and Coax Forum 15 03-13-2008 01:06 AM
PRO-2053 Audio hum keithmj Radio Shack Scanners 8 10-14-2007 05:38 PM
