Old 07-31-2009, 10:57 PM
Send a message via AIM to whitesox4life Send a message via Yahoo to whitesox4life
Wirelessly posted (LGE-VX9100/1.0 UP.Browser/6.2.3.2 (GUI) MMP/2.0)
i am using audacity to figure out paging tones...i have done it like the instructions said but none of the things under analyze are available
1RWN: IN12
Shack: Realistic Pro-52, Bearcat 155, Kenwood TK-270G, /\/\ Minitor IV
Old 07-31-2009, 11:07 PM
Chauffeur6's Avatar
What version of Audacity are you using? Here are some general instructions, might vary a little depending on the exact version you're using.
- Import the audio file with the tones
- Drag the cursor over the section of tone you want to analyze to select/highlight it (remembering that most tone sets are 1 second of Tone A followed by 3 seconds of Tone B)
- Analyze > Plot Spectrum
- Set Algorithm to "Spectrum", Function to "Rectangular Window", Size to "4096" and Axis to "Log Frequency"
- In the display window, hover the mouse cursor over the highest peak and read the Peak: value under the display. It will probably be a Hz or two off the standard tone, so take a look at a tone chart to get the actual Hz value that it most closely matches. So for example, 1819 Hz would actually be Plectron tone 1820 Hz
Old 08-01-2009, 01:03 AM
i figured out what the problem was. You have to play that section back before it unlocks the analyze things.
1RWN: IN12
