Originally Posted by pete133
i am running a feed with w.m.e. is there a way to add the rr feed to this program without running oddcast?
I used to use WME, But by default, WME only allows 5 connections simutaineously. I highly recommend you try using ScannerCast. It's 100% easier to use and alot better! You can get it by clicking
Here. Hope this helps!
Daniel
