Old 08-25-2009, 06:22 PM
robertpearsall's Avatar
Default Dual Sound cards
Need help configuring dual souds cards to run 2 streams and still have computer sound any help is appreciated
Robert
Motorola XTS2500 UHF
Uniden BCT15 x2
Old 09-09-2009, 10:02 AM
I could use some help as well, I installed another card and the one on the motherboard quit working so I bought another card and now neither of the 2 new ones or one on motherboard work LOL
Old 09-13-2009, 04:18 PM
Send a message via Yahoo to Ben96cal
Default multiple soundcards
they have to be of different make and model with different drivers. So you can't go out and buy 2 of the same and install or they won't work. Once you install the second one, if you have onboard sound that will diasble itself automatically.
Thanks,
Ben
Ca Online scanning
www.mattlogic.com
Old 10-04-2009, 01:59 AM
Send a message via AIM to SShuster221
Default Sound Cards
If you computer has the HP and the slots you can run as many feeds as you so desire. I have a computer running 4 feeds off one computer. Now where one user said they all have to be different cards is just not true. I have 4 of the same cards running all using line in, works just fine. Configuration is a pain cause you need to figure out what card is for what scanner.
Scott Shuster / Owner
www.LiveFireFeeds.com
Don't just hear it.. Experience it!!!
Old 10-04-2009, 02:37 PM
Forts's Avatar
Send a message via ICQ to Forts
This isn't entirely true, although it likely makes things easier. I've got a PC running with 2 Sound Blaster Live Gold cards in it (both cards are identical). You just need to be sure to manually assign different resources to the 2nd card (IRQ, base address etc etc). Things will work just fine after that. I use one card to feed an online stream, and the 2nd card to feed Trunk88.
Pro-106 - Pro-96 - BCT15 - BC780XLT - Pro-433 - Pro-2045 - BC-350 - Pro-43
Old 10-06-2009, 10:01 PM
w2lie's Avatar
Send a message via MSN to w2lie
I purchased a M-Audio card. it allows me to stream 4 scanners from the same card. you can also add multiple M-Audio cards (I forget the max amount).
so my current PC has 5 possible scanner streams. 4 inputs on the M-Audio card, plus the on board audio card (I had to go into the BIOS and enable it once I added the PCI Card)
73
Long Island Live Scanner Feeds: www.w2lie.net
Live Scanner Feeds On-Line of NCFD | NCPD | SCFD | SCPD | NYC-Harbor | "Specialty" Feed
Similar Threads
Vox2File/XCorder replacement for two sound cards.... RedPenguin General Scanning Forum 0 01-14-2009 12:20 AM
Two sound cards in the same machine... RedPenguin General Scanning Forum 14 01-13-2009 01:15 AM
Recording with a continious sound recorder..... RedPenguin General Scanning Forum 9 12-31-2008 12:17 PM
Sim Cards For Scanners khoelldobler General Scanning Forum 18 12-15-2008 01:03 AM
SWL Cards CryptoJoe HF/MW/LW General Discussion 7 08-22-2005 12:35 PM
