Old 09-15-2009, 08:48 PM
Question Two scanner feed
Can someone show me where I can find out how I set up a two scanner feed. I did a search on the forum but no luck finding it. Thanks
PRO-96 PRO-74 PRO-46 PRO-2042 PRO-2018 BEARCAT 145XL REGENCY R1070
Old 09-15-2009, 09:27 PM
n0nhp's Avatar
Send a message via Yahoo to n0nhp
Several ways to do it.
Do you want to set up a "stereo" feed or two separate feeds?
Stereo is pretty easy, Run the audio from each scanner into a stereo AUX input, change the feed software to stereo, and up the bit rate to double the mono rate (All after getting the ok from RR)
Two separate feeds usually requires a bit more and doing a search on this topic for "multiple feeds" will get you several posts on how others are doing it.
Bruce
N0NHP
Online Scanner http://www.radioreference.com/apps/audio/?ctid=279
