Old 10-21-2009, 05:50 PM
Default Radio Shack Pro-95 hum and low audio when streaming
Hey folks..
I just setup a new feed the other day..
Norwich Police and Fire Live Scanner Audio
When I stream my Radio Shack PRO-95 I get a crazy hum and the output of volume is very low.
Is this a common issue with the PRO-95 scanner?
I hooked up my older scanner PRO-82 same exact way and there is no hum and volume is fine So i am using the older scanner for now..
I want to use my PRO-95 because it has a lot more receiving power and frequency selection.
I will be buying a Ground Loop Isolator in a couple days that may help the hum but will it help the volume?
Anyone familiar?
What are my other options?
Thanks,
ScanDxer
Old 10-21-2009, 08:54 PM
Well I fixed it by fiddling with the headphone plug on my scanner..
I pulled the cable out of my scanners headphone jack just a little bit but not too much.
Maybe that turned it on mono ?
Works great now! No more hum and good volume now.
I hope this helps someone else..
