Old 10-26-2009, 11:57 PM
Default Transferring metadata through Oddcast
Hey all. I've been searching & searching to no avail, so now I'll just ask.
I have a new scanner feed. 396T through Oddcast to RR.com. Easy breezy, audio is working fine.
I now want to send tags. I figured out how to capture the tags showing in the Freescan virtual scanner and send them as metadata to Oddcast. They are showing up just fine in the Oddcast metadata window and changing when the TG changes. Good so far.
Problem is this. How do I get my tags to come through my feed? If I can see them in my Oddcast, shouldn't I easily be able to send them through my feed? Maybe I just need to click a couple of things and I'll be set.
Thanks in advance for any guidance.
MM
Old 10-27-2009, 02:34 PM
NYRHKY94's Avatar
I highly recommend switching over to ScannerCast for your RR feed. It's free and the setup is a breeze. It will automatically configure your RR feed for you and send alpha tags at the same time.
Give it a try:
K1PGV's ScannerCast
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
Old 10-27-2009, 04:25 PM
I have looked at that option. Thanks for the input.
But it still DOES NOT answer my question.
MM
Old 10-27-2009, 04:39 PM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
If Oddcast sees them RR should see them. Ensure you are using a player which supports the displaying of Alpha tags.
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 10-27-2009, 04:49 PM
ScannerCast is a cool program, but does not support tag streaming for any of my radio's. I used the metadata from the window that the Virtual Scanner is being controlled by with my BC246T. But it does not stream to any of the players. I might be doing something wrong, but I think I have it right. Which player supports tags?
Old 10-27-2009, 05:01 PM
As a mod, then maybe you can answer this question.
Does Oddcast support it? As I said, I see them in my Oddcast window on my end, so does that mean that they can be seen on my feed?
What steps do I need to take to make it so?
MM
Old 10-27-2009, 05:10 PM
bezking's Avatar
I'm not sure, I am going to let a Live Audio Admin handle this.
--bezking
Old 10-27-2009, 05:12 PM
It appears that RealPlayer shows the tags that I have inputed into Oddcast's metadata. The tag will show up when playing it from the stream.
Old 10-28-2009, 02:14 PM
Thanks Sherwood.
My alpha tags are now showing up in my feed.
MM
