I am currently using the RR version of K1PGV's Scanner Cast for my 2 audio feeds to RR. One feed is supporting ALPHA tags.
For ALPHA tags, in the next up date I would like to see a modification of "Diagnostic Information" found under the "Advanced" Tab.
Currently you can get the information that is being sent from the scanner through the Scanner Cast out to the audio server at RR.
However, this line is truncated due to the "Suspend sending tags" button.
I would like to see this information either under its own Tab or located where it can display all the information. Also it would be helpful if and if this was a choice, to have this information could be displayed in a small window when the program in minimized. It is a matter of convenience, sometimes the scanner that we are using for the audio feed in not close to the computer to see its display. I think this additional functionality would help keep an eye on the scanner from the computer desktop with out running across the room to check things.
My 2 bit suggestion...thanks for reading.
